Old 08-20-2012, 07:22 PM   #1
sirhc
sirhc's Avatar
Drives: fr-s
DIY install ISIS catback exhaust
This is going to be purely a How To: for review http://www.ft86club.com/forums/showt...674#post391674.
I did this on the floor of my garage. The whole install took 45 minutes from beginning to end including me taking the pictures.
This is what you will get in your box
You will need a jack, jack stands. 14mm socket, ratchet, 14mm wrench, medium size channel locks, and some penetration lube of choice I used WD-40
1: I raised up my car from the drivers side installing the jackstand at the rear subframe mounting, and the front frame mounting.
2:remove the bolts with the 14mm socket and wrench on the axle back and the mid pipe.
3: use the 14mm socket to remove the bolts with springs and separate the midpipe from downpipe. you can use your hands to hold the smaller bolts on the other end.
4: take the WD-40 and spray some inside the rubber exhaust hanger and use the channel locks to push the nipple through
once removed it will look like this
5: go to the muffler and use the WD-40 on those rubber hangers and use the channel locks in the same manor, it doesnt matter wich side you start from but I suggest you release both on the same side before going to the other will make removing easier
once removed it shall look like this
6:I didnt but I suggest you bolt the two midpipe sections together with provided bolts and gasket before you install it will make it easier.
7: put some lube on the hanger again and slide the nipple through the rubber hanger. sorry no pic for his
8: put the bolts with springs back in and reconnect the midpipe to the downpipe, you may want to use the channel locks to squeeze the spring and bolt to start the nut on the back
9: install the muffler in the reverse manner you removed it, spray some lube in the hangers and install one side at a time. it makes it easier for leverage.
10: connect the midpipe to the axle back with the supplied nut, bolts and gasket and your done.
Again this was extreamly simple probobly one of the easiest exhaust systems I have ever installed on my car.
thanks
Chris
sirhc is offline   Reply With Quote
Old 08-20-2012, 11:07 PM   #2
Mister_Sir
Mister_Sir's Avatar
Drives: 2013 Scion FRS
What suspension are you on? Thats a good drop
Mister_Sir is offline   Reply With Quote
Old 08-20-2012, 11:10 PM   #3
sirhc
sirhc's Avatar
Drives: fr-s
Bc Racing
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Old 08-21-2012, 12:19 PM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 08-22-2012, 04:26 AM   #5
Ms. FR-S
Drives: 2013 Scion FR-S, 1993 Mazda RX-7
Thanks for this! Just got mine last night, this will be a great help for installation.
Ms. FR-S is offline   Reply With Quote
Old 09-26-2012, 11:27 AM   #6
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
Well done! Although I won't be using this exact cat system, the write up is clean and simple. Ill wait for a video version (if possible) since i have a LONG wait for my system and break in
Thanks again!
ProjectD is offline   Reply With Quote
Old 01-30-2013, 02:01 PM   #7
AlmightyNub
AlmightyNub's Avatar
Drives: Scion FRS - Whiteout
Looking great!
AlmightyNub is offline   Reply With Quote
Old 09-12-2013, 12:19 PM   #8
JR007
JR007's Avatar
Drives: Ultramarine FR-S
Sweet, thanks for the instructions!
JR007 is offline   Reply With Quote
Old 12-23-2013, 03:53 PM   #9
CatDaddysBBQ
Drives: '13 FR-S
I love the sound of the Isis cat-back from the youtube vids i've seen - it's probably my fav.
Though i'm not such a fan of the burnt tip look, I think this is nearly the top of the list when I end up buying one this year.
In your opinion, is it reasonably "gentlemanly" or is it really freaking loud? I'm just wondering - the sound is great, but you can never get an idea of volume in a youtube vid.
CatDaddysBBQ is offline   Reply With Quote
Old 12-24-2013, 09:31 PM   #10
2beFrank
2beFrank's Avatar
Drives: Firestorm 6MT
I also have the Isis cat. It is definitely not freaking loud. I originally didn't want something too loud, because of neighbors. After getting it on, I do wish it was a tad louder. But it sounds much, much better than stock
2beFrank is offline   Reply With Quote
Old 12-24-2013, 09:44 PM   #11
samfrs
Custom User Title
Drives: FRS
That look sexy. Price and sound clip? Sorry a lil lazy to search
samfrs is offline   Reply With Quote
Old 03-13-2014, 03:41 AM   #12
BRAWL
Drives: Toyota 86 GTS Velocity Orange
All picture links are dead. Need to re host or fix link
BRAWL is offline   Reply With Quote
Old 07-10-2015, 10:33 AM   #13
CircaBRZ
CircaBRZ's Avatar
Drives: 2013 BR-Z Limited
Replace with this please
http://www.moddit.com/Guide/How+to+I...+a+BRZ/27#s346
CircaBRZ is offline   Reply With Quote
Old 07-10-2015, 10:33 AM   #14
CircaBRZ
CircaBRZ's Avatar
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
Catback exhaust opinions? Ms. FR-S Southern California 34 10-22-2012 07:37 PM
Catback Exhaust vs Axleback Exhaust – What’s the difference? phenom86 Engine, Exhaust, Transmission 10 07-28-2012 09:08 AM
ISIS Performance Prototype Scion FR-S/BRZ Exhaust Enjuku Racing Engine, Exhaust, Transmission 35 07-19-2012 03:34 PM
