If you were wondering about that little split in your axles boots...
Gulp...found these rocks/stones/boulders...inside one of my CV joints.
I had noticed a small split for a little while on the Driveshaft Shop 800hp axle, but there was no grease leaking out, and the split seamed to be small and "closed"... so I ignored it for a couple of months. Finally thought I should change the boot. The grease was still intact..but loaded with various sized pieces of gravel ...and gawd knows what else. Admittedly I do a lot of driving on dirt, but it still blows my mind that : A- How stupid I am (and) B- What can work its way into quite a small split in a rubber boot. Luckily after a full clean and re-lube the CV is as good as new..and is a testament to what one of their axles can cope with. |
| The Following 4 Users Say Thank You to grumpysnapper For This Useful Post: |
Rust bucket enthusiast
Maybe the projectile nature of the rocks means they lanced the surface, leaving only a small bit of evidence of the entry? Crazy lucky they didn't cause any harm. Now I want to check mine
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
| The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | grumpysnapper (10-01-2022), Ultramaroon (10-02-2022) |
ProCrastinationConsultant
considering how much time you spend off paved roads, perhaps some underbody protection should be in order. at least in the form of some lexan/plexiglass/mud flap ziptied to the lower arm mount just to deflect the gunk away from the cv axles!
| The Following User Says Thank You to soundman98 For This Useful Post: | grumpysnapper (10-01-2022) |
#4 | |
| The Following 2 Users Say Thank You to grumpysnapper For This Useful Post: | soundman98 (10-01-2022), Ultramaroon (10-02-2022) |
nah, blame the car. it can always be something or someone else's fault!
you should press charges against the sanctioning body for leaving pebbles on the race course!
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
not playing cards
He's Aussie, not 'Murican, land of the litigous, home of the contingent.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | grumpysnapper (10-02-2022) |
i just think it'd be funny to attempt to sue an offroad sanctioning body for 'dirt on the course'
be like a surfer complaining about the size of the waves!
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | grumpysnapper (10-02-2022), Ultramaroon (10-02-2022) |
LMGTFY
Drives: 13 FRS, 91 Miata
| The Following 2 Users Say Thank You to x808drifter For This Useful Post: | grumpysnapper (10-02-2022), Ultramaroon (10-02-2022) |
| AutoStyled - Hand-Crafted Shift Knobs/Shift Boots/Brake Boots Are Now Here! | RallySport Direct | Interior Parts (Incl. Lighting) | 4 | 06-23-2017 02:37 PM |
| TOM'S 4 spoke split wheels - thoughts? | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 41 | 07-10-2013 05:45 PM |
| FRS Electronics shutting off for split second? | sega_102 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 05-15-2013 12:32 PM |
| TRD 18x7.5 Split Spoke | m.box.design | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 06-22-2012 07:56 PM |
