Old 05-13-2013, 09:53 AM   #1
sega_102
Drives: Scion FR-S
FRS Electronics shutting off for split second?
I've had my FRS since August. The following problem has occurred 5 times. Once Friday, Three times Sunday and once this morning.
When driving, the car jerks and all the electronics shut off for about a half a second. Then they all come back on. All the lights light up just like you are starting the car. The car then drives normally.
The first time it happened, I was pulling out of first gear.
The 2nd time I was accelerating going about 60 on an interstate ramp.
Third and fourth times I was coming to a stop.
5th time I was accelerating from a stop.
Has anyone had a problem like this? I don't really know how to replicate the issue.
I'm taking it to Toyota tomorrow.
sega_102 is offline   Reply With Quote
Old 05-13-2013, 10:01 AM   #2
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
It hasn't happened to me (owned since last August). It only (almost) happens when I get dangerously close to stalling. Does your RPMs dip really low and your engine starts sounding really grumpy?
However, you said that it also happened when you were accelerating. That's definitely an issue so yes, bring it in.
Books is offline   Reply With Quote
Old 05-13-2013, 10:03 AM   #3
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Assuming you have a M/T. 1st, 3rd, 4th and 5th times sound like you're almost stalling the car. Give it a bit more gas when you're rolling from a stop. Sounds like you're letting off the clutch pedal without enough gas. When you're slowing down, you may be letting your engine RPM drop too low by leaving it in a higher gear, or depressing the clutch too late. No idea about your 2nd time.
raul is offline   Reply With Quote
Old 05-13-2013, 10:08 AM   #4
sega_102
Drives: Scion FR-S
That's what I thought after the first time. I thought I just screwed up and stalled it. I wasn't paying any attention.
The time when it did this when I was decelerating, I was only going about 5 mph and the car was in neutral. There's no way I stalled it.
The tachometer drops to 0 when this happens, but I'm not so sure the engine is stalling.
I've been driving a manual for 12 years now. I know I'm not stalling it, but I have no clue where the problem could be coming from.
Old 05-13-2013, 10:13 AM   #5
Gen
Drives: Scion FR-S
You may not have been but the car was most likely very close to stalling. When my car was new the car would have a fluctuating idle and come very close to stalling on its own every so often, even when decelerating.
Gen is offline   Reply With Quote
Old 05-13-2013, 10:24 AM   #6
sega_102
Drives: Scion FR-S
Hmmm, It does have a really rough idle when I'm sitting at stoplights.
That could have something to do with it. I wonder why it just started though?
Old 05-13-2013, 03:28 PM   #7
Skywgn1
Skywgn1's Avatar
Drives: 2013 Scion FR-S (manual)
Take it to the dealership and hope they fail trying to fix it 3 times. Start the lemon process and get the new model without the problems. Good luck.
Customize the piss out of it and call it yours!
Skywgn1 is offline   Reply With Quote
Old 05-13-2013, 03:31 PM   #8
CBR600RR
Drives: Raven Black
check that the battery terminals are tight
Old 05-14-2013, 06:03 AM   #9
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
If it feels like someone just unplugged the car for a second then plugged it back in, I had this happen on a car a few years back. Even after a dozen trips to the dealer (under warranty) no one could ever figure it out. They guessed it had to be something electrical shorting out but could never track it down. And the circumstances when it would occur were never consistant.
It made me crazy to wonder when it would happen next so I ended up dumping the car. I hope you have better luck with yours. At least the diagnostic technology is better today.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 05-15-2013, 11:32 AM   #10
sega_102
Drives: Scion FR-S
Toyota fixed the issue.
Somehow the metal battery holder came loose and came into contact with the positive battery terminal.
Not sure how that happened as I never touched that piece.
Nifty electronics mods proficience AUSTRALIA 41 05-13-2013 02:09 AM
Suggestion: Split up the engine/exhaust/etc.. dsmx17 Site Announcements / Questions / Issues 2 10-18-2012 04:38 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
TRD 18x7.5 Split Spoke m.box.design Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-22-2012 06:56 PM
