Old 10-01-2022, 10:50 AM   #1
grumpysnapper
grumpysnapper's Avatar
If you were wondering about that little split in your axles boots...
Gulp...found these rocks/stones/boulders...inside one of my CV joints.
I had noticed a small split for a little while on the Driveshaft Shop 800hp axle, but there was no grease leaking out, and the split seamed to be small and "closed"... so I ignored it for a couple of months.
Finally thought I should change the boot. The grease was still intact..but loaded with various sized pieces of gravel ...and gawd knows what else.
Admittedly I do a lot of driving on dirt, but it still blows my mind that :
A- How stupid I am
(and)
B- What can work its way into quite a small split in a rubber boot.
Luckily after a full clean and re-lube the CV is as good as new..and is a testament to what one of their axles can cope with.
grumpysnapper is offline   Reply With Quote
The Following 4 Users Say Thank You to grumpysnapper For This Useful Post:
DarkPira7e (10-01-2022), jcw99 (10-04-2022), soundman98 (10-01-2022), Ultramaroon (10-02-2022)
Old 10-01-2022, 10:53 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Maybe the projectile nature of the rocks means they lanced the surface, leaving only a small bit of evidence of the entry? Crazy lucky they didn't cause any harm. Now I want to check mine
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
grumpysnapper (10-01-2022), Ultramaroon (10-02-2022)
Old 10-01-2022, 10:57 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
considering how much time you spend off paved roads, perhaps some underbody protection should be in order. at least in the form of some lexan/plexiglass/mud flap ziptied to the lower arm mount just to deflect the gunk away from the cv axles!
Old 10-01-2022, 11:07 AM   #4
grumpysnapper
True...And/Or I should not be a lazy bugger on maintenance
The Following 2 Users Say Thank You to grumpysnapper For This Useful Post:
Old 10-01-2022, 11:48 AM   #5
soundman98
soundman98's Avatar
nah, blame the car. it can always be something or someone else's fault!
you should press charges against the sanctioning body for leaving pebbles on the race course!
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
grumpysnapper (10-01-2022), new2subaru (10-01-2022), x808drifter (10-02-2022)
Old 10-02-2022, 12:18 AM   #6
He's Aussie, not 'Murican, land of the litigous, home of the contingent.
grumpysnapper (10-02-2022)
Old 10-02-2022, 12:59 AM   #7
soundman98
soundman98's Avatar
i just think it'd be funny to attempt to sue an offroad sanctioning body for 'dirt on the course'
be like a surfer complaining about the size of the waves!
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
grumpysnapper (10-02-2022), Ultramaroon (10-02-2022)
Old 10-02-2022, 09:23 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Well any TURE race driver blame anyone/everything but themselves.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
AutoStyled - Hand-Crafted Shift Knobs/Shift Boots/Brake Boots Are Now Here! RallySport Direct Interior Parts (Incl. Lighting) 4 06-23-2017 02:37 PM
TOM'S 4 spoke split wheels - thoughts? GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 07-10-2013 05:45 PM
FRS Electronics shutting off for split second? sega_102 Scion FR-S / Toyota 86 GT86 General Forum 9 05-15-2013 12:32 PM
TRD 18x7.5 Split Spoke m.box.design Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-22-2012 07:56 PM
