Drives: Truck
Trans rebuild OEM
Doing some searching online and not finding too much on rebuilding the transmission on these cars. My 5th and 6th gear grind above 4K Rpm. I mostly drive highways so I don't spend a terribly long amount of time shifting in these gears but it is annoying when I need to pass someone.
Is everyone just replacing transmissions when/if this happens? Car has a little over 130k on it. |
Drives: Crapcan
When is the last time you changed the transmission fluid and what are you running for fluid? Good fluid makes a huge difference.
Used transmissions are 4-600 so people don't really rebuild them, problem is you don't know what you are going to get used. I would call a local transmission place for a quote, snycro's maybe toast, they are a bit sensitive in these.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | DarkPira7e (09-27-2022) |
| Engine rebuild | Locost7 | Engine, Exhaust, Transmission | 2 | 09-14-2020 01:50 PM |
| Can RSR coilovers be rebuild? | ysr50guy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-19-2017 01:34 PM |
| '13 Subaru BRZ rebuild | P3tras | Member's Car Journals | 96 | 01-03-2016 07:05 PM |
| Looking to rebuild a Scion FRS | miller.4311 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 06-24-2015 07:47 PM |
| fs: Perrin trans mount and whiteline trans bushing | RWD_FR-S | Transmission and Driveline | 1 | 01-02-2014 06:34 PM |
