Old 08-14-2017, 11:42 PM   #1
ysr50guy
ysr50guy's Avatar
Drives: brz
Can RSR coilovers be rebuild?
After a lot of miles I feel like my RSR Black-I coilovers need a rebuild. Anybody know of a good shop that can rebuild them? Are they even rebuildable? I know it was possible with my old KW v3's
ysr50guy is offline   Reply With Quote
Old 08-15-2017, 12:05 AM   #2
swarb
http://fealsuspensionstore.com
Are you looking for any ysr50 stuff? LMK
Old 08-15-2017, 12:10 AM   #3
strat61caster
strat61caster's Avatar
Best bet would be to email or call RS-R US offices, they should be able to point you to a local rebuilder if possible, if CA means SoCal you may even be able to take them to the source.
http://www.rs-r.com/contact/
However don't be surprised if they do not offer a rebuild service and would rather sell you a set of replacement dampers. They look a bit like BC/Megan units, so there may be someone willing to rebuild out there given that Feal and Fortune Auto are willing to rebuild theirs (and others) units which are based on the BC/Megan/Godspeed/etc. hardware. Find your local racers, there's likely a little tuning shop that can and will do a rebuild for a reasonable price if they're familiar with the hardware.
http://fealsuspensionstore.com/coilo...es/#coilover-1
ineedyourdiddly
Old 08-15-2017, 10:06 AM   #4
twag4
Drives: frs
They are not BC/Megan racing units at all. Im fairly confident they are rebuildable.
twag4 is offline   Reply With Quote
Old 08-16-2017, 04:14 AM   #5
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Yes they can. Contact the RS-R US headquarters.
CounterSpace Garage is offline   Reply With Quote
Old 08-19-2017, 12:05 AM   #6
ysr50guy
ysr50guy's Avatar
Drives: brz
So I contacted Feel Suspension and they said their not sure if they can do it but I can drop them off so they can take a look but unfortunately I'm not local.
I also contacted RSR and they said no problem for $250 a piece plus parts if their needed which ends up being 1K minimum for all four and they will have to order parts from Japan which will take awhile. I feel that's a little to expensive.
Anyone has any more recommendations?
Old 08-19-2017, 12:34 PM   #7
CounterSpace Garage
It's more of a liability issue and the capacity to build up to that quality standard as well as providing the proper components to perform the rebuild. Generally speaking, you will want to keep manufacturers strict to their system in order to maintain that level of quality. RS-R generally ships their kit out to Japan for rebuild.
LQ4 6.0L V8 swap (LS3 rebuild) nmctacticz Engine Swaps 12 11-24-2018 07:59 PM
BRZ Rebuild (Mulekr1) mulekr1 Member's Car Journals 3 11-15-2015 10:53 AM
rebuild FR-S Raven FR-S_AV Member's Car Journals 9 06-20-2015 01:44 AM
How often to rebuild coilovers or stock shocks? stockysnail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 12-24-2012 12:54 PM
