Old 08-29-2022, 03:13 AM   #1
Ace23_BRZ
Ace23_BRZ's Avatar
Drives: 2013 Subaru BRZ
Question Installing Dual SPAL Fans
Hello All!
I'm pretty sure a few of you folks have installed a dual SPAL fan setup and I would like to tap into that knowledge.
I am going to install my Koyo radiator along with a dual SPAL fan setup, however, I noticed the two fan clips on the SPAL fans are different from the ones on my 2013 BRZ.
Should I just invest in a prefabricated wire harness, like from Chasebays, SPAL, etc?
Or is there a way to run these fans in line with the pre-existing wiring?
Thanks in advance!
V/R,
Ace
Ace23_BRZ is offline   Reply With Quote
Old 08-29-2022, 04:23 AM   #2
Ace23_BRZ
Ace23_BRZ's Avatar
Well, if anyone is interested, I found this video, and will probably do the same...
Old 09-02-2022, 03:54 PM   #3
RedReplicant
Drives: None
Be careful, the previous owner of one of my cars wired the SPAL fans to the stock connectors and I found they'd intermittently pop the 20a fuses. I ended up wiring them to a 30a relay each.
RedReplicant is offline   Reply With Quote
Old 09-02-2022, 09:02 PM   #4
Ace23_BRZ
Ace23_BRZ's Avatar
Oh, good to know...yeah, I'll check out the circuitry requirements prior to final installation.
If this is the case, and since I am rewiring into the current fuse lines, I could just install 30amp fuses in their current place, right?
Thanks,
Ace
Old 09-03-2022, 01:23 PM   #5
RedReplicant
Drives: None
Thanks,
Ace
You could, but I opted not to go that path due to the size of the stock fan wiring not being the correct gauge for 30a.
Old 09-04-2022, 02:51 AM   #6
Ace23_BRZ
Ace23_BRZ's Avatar
So what did you do?
How did you wire your fans?
Did you wire a separate dedicated fuse block?
Thanks!
Old 09-04-2022, 03:41 PM   #7
RedReplicant
Drives: None
So what did you do?
Thanks!
I wired in two of these: https://www.amazon.com/gp/product/B003PB4AY8/
Ignore the ugly wiring, there are two pictures here https://www.ft86club.com/forums/show...1&postcount=18
You basically wire the fans to the relays and use the stock fan wires to signal the relays.
Old 09-04-2022, 06:25 PM   #8
Ace23_BRZ
Ace23_BRZ's Avatar
Haha, gotcha...I was trying to do this install without the use of that kit, but I'd rather be safe than sorry.
I'll err on the side of caution and get that relay kit myself.
Also, I'm assuming no issues since?
Thanks in advance!
Old 09-04-2022, 08:02 PM   #9
RedReplicant
Drives: None
Thanks in advance!
Everything has been great since putting them in. Probably a much cleaner way to do the wiring that I did though, haha.
Old 09-04-2022, 08:28 PM   #10
Ace23_BRZ
Ace23_BRZ's Avatar
LoL, all good...you can always make it better later.
Same here bro, and since I am very OCD when it comes to my project builds, I am treating this one no different.
Ha, I am stumped right now though, you see, I want to rejuvenate and re-loom my harnesses.
One, I want to clean up my engine bay, two, I would like to extend and tuck my wires elsewhere like my light harnesses, and everything else that will be exposed to the high heat temperatures all while making the entire harness brand new.
LoL, I am thinking that pulling the harness from the interior out is the simplest way, rather than yanking the engine harness through the firewall.
I mean, from the images below, unclipping the connectors from the interior cabin seems like an easier task, especially since I still have my motor in.
And yeah, I'm keeping the motor in, because I am taking my car to the paint shop in a couple of weeks to install my wb fenders so that I can run my Work Meisters S1 3Ps .
Old 09-05-2022, 12:26 PM   #11
RedReplicant
Drives: None
Oh, man, that looks like a pain, haha. Looks like it'll all be worth it in the end, I subbed to your build thread
Old 09-05-2022, 09:32 PM   #12
Ace23_BRZ
Ace23_BRZ's Avatar
OMG it is...and what's worse, Subaru decided to make the engine harness simple, yet wiring every fucking thing else into one harness .
Regardless, I am going to see if I can create/fabricate my own harnesses.
Of course, I am going to use OHM's law with TXL and/or Tefzel wire to reproduce such a product.
I mean, best case, I create an amazing harness while gaining a tremendous amount of electrical knowledge along with the satisfaction of having a killer harness and amazing-looking engine bay.
Worst case, well, learning a very expensive mistake, yet still learning a tremendous amount of fuckable experience. LoL
Full Blown Radiator + Fan Shroud + 2 Spal (12") Slim Fans R2RO Engine, Exhaust, Bolt-Ons 14 08-29-2019 12:50 AM
Help installing Berk Technology Dual Tip Muffler Delete Riftur Southeast 3 01-26-2017 01:55 PM
Quick Question about installing a CAI Ensanety Engine, Exhaust, Transmission 4 04-17-2015 12:41 AM
Stock radiator + aftermarket Shroud to fit SPAL fans jflogerzi Forced Induction 18 09-08-2014 11:55 PM
Question for Subaru veteran repair and ecu guys:radiator fans Huehuecoyotl Engine, Exhaust, Transmission 11 04-14-2014 06:19 AM
