| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
AT 2013 BRZ stalls braking hard
My 2013 AT BRZ stalls when I brake hard due to rpm dropping below 500. When it stalls I put it back in park and start it again. I’ve cleaned throttle body it seemed to have gotten better but still stalls when I test it out. Does anyone know what the problem might be ?
Rust bucket enthusiast
Is your car tuned? What non-oem parts are on the car? Why are you braking hard? Have you considered consulting a shop or the dealer?
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
No tune , just a cat back exhaust . It shouldn’t still regardless of why I’m braking hard , even when I stop rapidly at a stop sign the rpm drops and the car is joking.
But that’s for scion FRS or 2013 BRZ have the same issue ? Also , mine is over 100k miles so …
Geo Tyrebighter Esq
Drives: '13 scion fr-s
They're exactly the same other than front bumper and some paint colors.
"I gotta rock." -- Charley Brown |
LMGTFY
Drives: 13 FRS, 91 Miata
What bcj said
There they're same f-ing car!!! |
I know but it just said that some of the FRS vehicles may experience that I thought maybe BRZ was didn’t have that defective ECM.
Subaru will have a similar bulletin with the same fix (as said same car) it just isn't posted here.
#10 |
Drives: 2018 BRZ
My previous car, AT 2011 scion tC would stall occasionally when braking hard to a stop. Just had an axle back and intake with no tune, but discovered it’d do that because my oil was low. Like just barely on the dipstick low. Changed and added more oil and it fixed the stalling problem for me.
It’s a different car, but might be the same problem it had ? Check your oil pressure and levels. |
| Is this normal? rpm drop when hard braking | szjalo | Issues | Warranty | Recalls / TSB | 11 | 02-23-2017 08:34 PM |
| Foot pain while braking hard? | daiheadjai | Other Vehicles & General Automotive Discussions | 19 | 04-05-2015 08:46 PM |
| Oversteer Under Hard Braking | learnerspermit | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 07-13-2014 12:20 PM |
| car pulls to right when braking hard.. | VoiD | Issues | Warranty | Recalls / TSB | 15 | 12-17-2013 05:26 PM |
| Wheel Hop When Braking Hard | Bonburner | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 01-14-2013 09:31 PM |
