Old 08-21-2022, 06:15 AM   #1
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
[CLOSED] Used Gen1 OEM Fuel Pump Assembly
** Please close. This item is no longer availble. **
Free picked up in Southern California or shipped at your expense
Local pick-up or ship only. Not meeting halfway, just not worth the time and effort.
Complete, used OEM Fuel Pump Assembly / Sending Unit (Basket, Filter, Float Sensor, and Pump); also includes with tank gasket and lid gasket, but recommend replacing as they are indicated as one-time-use. This that sits behind the driver. Corresponds to prior revision part: Toyota SU00301018 / Subaru 42021CA000
Perfect for anyone who wants an extra unit for modding / forced induction.
Came out of my 2014 Scion FR-S, 127k miles. I replaced it with a new unit as part of preventative maintenance. Run with primarily E85 the last two years. The pump and float sensor were working as normal when removed.
EndlessAzure is offline
WTB: OEM fr-s/brz fuel pump hanger assembly Clash0901 Want-To-Buy Requests 0 02-16-2018 09:19 AM
Fuel Pump Assembly Question amanzoli Issues | Warranty | Recalls / TSB 21 01-09-2018 07:25 PM
Fuel pump assembly: Fuel pressure regulator popping out sfruski Engine, Exhaust, Transmission 2 09-15-2017 09:39 PM
OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu ndreim Engine, Exhaust, Bolt-Ons 5 11-23-2016 11:36 PM
FS SOCAL: Perrin Oil Cooler, Koyo Radiator, ECU, Stock Fuel Pump Assembly John Rambo Engine, Exhaust, Bolt-Ons 8 04-26-2016 01:57 PM
