| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 13 BRZ, 06 M3
AC Issue *WIRING CHALLENGE*
AC does not work.
All the wires for the AC compressor are fine. Relay and fuse are fine. Here is what I found: -The voltage going into the AC relay is 4.5V when the AC button is toggled off, and 0V when the AC button is toggled on. This is not enough to trip the relay I assume. -Power going into the relay for the compressor is +12V. No problem there. -I pulled the climate control module out and checked continuity for all of the pins. From left to right I measured: Nothing, Ground, High resistance, Ground, Ground, 12V, 4.5V, Nothing, Nothing. Looking at the wiring diagram, shouldn't pin 6 be 0V? That is the pin that would lead to the AC comp relay correct? My question is: -Shouldn't the relay get 12V when the AC button is toggled on? -Where is the 4.5V coming from? -Where do I go from here? Thanks in advance! |
not playing cards
I challenge you to start from the beginning.
![]() HEATING / AIR CONDITIONING: AIR CONDITIONING SYSTEM (for Automatic Air Conditioning System): PROBLEM SYMPTOMS TABLE HEATING / AIR CONDITIONING: AIR CONDITIONING SYSTEM (for Automatic Air Conditioning System): DIAGNOSIS SYSTEM
| Tags |
| air conditioning, compressor, electrical, troubleshooting |
| 2013 FR-S wiring issue | Willy Smith | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 12-07-2019 10:27 PM |
| FRS 2jz wiring issue... | theswap09 | Software Tuning | 1 | 12-28-2015 09:30 PM |
| Fog Light Wiring Issue! | ToyoGT86 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 10-24-2013 01:45 AM |
| Fog Light Wiring issue? | ToyoGT86 | Electronics | Audio | NAV | Infotainment | 0 | 10-23-2013 11:25 PM |
| Head unit wiring issue. Please help | ph0en1xtk | Electronics | Audio | NAV | Infotainment | 3 | 04-02-2013 06:50 PM |
