Old 03-31-2013, 10:48 AM   #1
ph0en1xtk
ph0en1xtk's Avatar
Drives: Raven MT Scion FR-S
Head unit wiring issue. Please help
Hello there everyone. I recently purchased a new head unit for my 86, along with the metra harness and dash kit. I had the unit installed just fine for about 2 weeks, with no problems at all, but when i went to test my rear view camera that i bought separately, i think i shorted something out. Immediately after hooking it up, the screen on my HU just shows white and is unresponsive. Thinking i shorted out the harness, i unhooked everything and tried hooking the unit up directly to the battery by touching the wires to the 2 battery terminals. Doing that made it boot up like normal, with no problems at all. So thinking i was right in shorting the harness, i took the opportunity to order the beatsonic harness and dash kit (as i was having problems with the metra fitment) and much to my dismay, i had the exact same problem with this one as well, now the unit wont even boot on at all from the harness, but still works fine on the battery (again)
This led me to believe that something is shorted even further down the line, but to me this doesnt make sense, because reinstalling my stock head unit works perfectly fine.
Can someone shed some light on this, as im at my wits end now, and im trying to avoid taking it to an expensive audio installer just to troubleshoot.
ph0en1xtk is offline   Reply With Quote
Old 03-31-2013, 10:51 AM   #2
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
Check if you have a good ground. Or add a separate ground.
I'll be back!!
F3dzo is offline   Reply With Quote
Old 03-31-2013, 11:00 AM   #3
ph0en1xtk
ph0en1xtk's Avatar
on the metra kit, it had a ground wire connection, but the beatsonic does not. I attached the ground wire from the HU to a metal bit on the inside of the dash. Should that be alright?
Old 04-02-2013, 06:50 PM   #4
ph0en1xtk
ph0en1xtk's Avatar
anyone got any ideas? still cant get it to come up
BRZ Head Unit RedRocket Audio/Visual, Electronics, Infotainment, NAV 2 06-25-2013 10:21 PM
Factory head unit wiring help please. jabbajaw99 Electronics | Audio | NAV | Infotainment 2 03-24-2013 06:09 PM
New Head Unit Wiring Question sikest Electronics | Audio | NAV | Infotainment 2 01-17-2013 05:15 PM
FRS aftermarket head unit installation - wiring MindtheGap Electronics | Audio | NAV | Infotainment 35 01-14-2013 09:00 PM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 07:42 PM
