Drives: GT86 2015 GTX (Manual Transmission)
Hi,
A few months ago I hit a pothole at quite a high speed, right after the incident there was intense vibration from the car and the steering wheel went soft. The car stabilized after 10 -15 seconds but since then I've been having this clunking sound when I steer the wheel, apply the brakes, or drive over bumpy roads. https://www.youtube.com/shorts/SARgvsJ0kaQ Mechanics recommended changing the suspension back to stock but to no avail. Any body experienced this issue before? |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
In video form, that does not sound like it's coming from under the car. Suspension clunks will typically resonate in the chassis and sound much deeper, that clanking sounds like it's coming from inside the car, or at the very least hitting right at the sheet metal of the passenger compartment.
If it were me I'd stretch my arm under the dash and check the steering shaft. Might be play at the power steering unit or at the rack input shaft, or you might have sheared one of the bolts mounting the rack to the subframe. Also, just because it's easy, check the strut bars under the hood, if the hit was hard enough, one of those could be popping at the mounting points, and those pops would go up the rod and into the firewall like a speaker. |
#3 | |
Thanks a lot, I will get the steering checked and report back with the findings. |
Drives: GR86
Sounds to me like its inside the cabin too - like you knocked some panel or trim piece out of place. Might go around the cabin from ceiling to the floor banging on every piece of plastic you can see - in addition to inspecting steering components since something could have gone out of whack with a really hard hit.
I'd suggest you check the front wheel bearings and front brake calipers.
The last time I heard something like that, it was coming from an empty, steel wheeled, hay wagon being pulled down a washboard lane.
Drives: 17 Asphalt 86
I've had bolts come lose and absolutely drive me nuts around the dash. Might be worth pulling the tweeter speaker panel off and checking the screws.
#7 | |
Drives: 2018 Subaru BRZ
I also think it is the wheel bearings. It either sounds like there's metal grinding while on the highway, or a clunking noise whenever turning-going over small bumps.
Drives: car
All the above comments, lol you guys should try better to stay current with the issues on these cars. This issue has been covered multiple times and should be well-known by now!
It's the electric power steering coupler. It makes corrections over bumps and rough pavement, and rattles if it has a broken part. The power steering behind your steering wheel has a worn or shredded bushing, a $20 replacement part. Here's the repair procedure for the 86 / FR-S / BRZ EPS electric power steering coupler: https://www.ft86club.com/forums/showthread.php?t=133606 Last edited by radroach; 08-15-2022 at 01:02 PM. |
#10 |
ProCrastinationConsultant
stay current, i'm still trying to catch up to the past!
#11 |
Yep, I hear that and I got a long way to catch up -
![]() "hang on, I'm ah reachen fer the road gear" -
#12 |
Drives: WRB BRZ
possibly the electric poer steering steering damper\coupler
part is like $5 but about 2 hours of fun to install https://www.ft86club.com/forums/showthread.php?t=133606 think there is some youtube videos on replacent as well |
#13 |
LMGTFY
Drives: 13 FRS, 91 Miata
Hope it's not this... (This is a joke of course.)
Skip to 0:48 |
| Tags |
| clunking, issue, steering |
| Rear Clunking Sound. Help! | Trev6450w | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 09-06-2021 09:36 AM |
| Clunking Sound from Steering Related Parts | MCTeeJ | Issues | Warranty | Recalls / TSB | 2 | 02-27-2020 04:40 PM |
| Clunking sound after coilover install | Dee | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 09-22-2018 04:12 PM |
| Clunking sound coming from suspension | Maverickgear | Issues | Warranty | Recalls / TSB | 9 | 07-11-2014 02:41 PM |
| Neutral to 1st clunking sound | wallace03 | Issues | Warranty | Recalls / TSB | 3 | 01-10-2013 09:50 PM |
