Drives: 2013 Scion10 FRS
FRS 2013 doesn`t start after swap
Hi, guys here the deal:
I have bought Scion FRS 2013 with blown engine, replaced the engine for a rebild one, and its cranking but not start, there is no spark and injectors are not opening. Fuel goes into the ramp. Replaced crankshaft position sensor, but nothing have changed.. DTC shows codes: p1640 U0100 Would be glad for any thoughts and advice |
Drives: 2013 frs base
If you haven't already, recheck all of electronic connections.
ProCrastinationConsultant
what model year engine did you install?
is the DI module bolted/down and grounded?
AutoX-10/10ths every run
Simple web search, may not be accurate seems to point to faults with the Engine Control Module. I'd verify that your engine harness is connected correctly. Might need a new engine harness?
| The Following User Says Thank You to whataboutbob For This Useful Post: | FRSapex (08-11-2022) |
that would be the first thing to figure out. the cam indicators changed in 15 along with some other updates, so a 15+ motor in a 13-14 requires additional work
| The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
OK don't take this as me thinking poorly of you but the question needs to be asked.
Have you checked all fuses and relays?
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | DarkPira7e (08-10-2022), soundman98 (08-11-2022) |
#10 |
Rust bucket enthusiast
The engine has a turbo on it, what is the MAP size? What parts have been swapped from your old build to this one? Honestly you'd be better off getting it running on a stock map with stock intake/ exhaust manifold if you're having issues
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | alphasaur (08-10-2022) |
#11 | ||
. What happend we may only guess))Parts • [1 Mishimoto oil cooler (off the car) • [1 Injen Air Intake (off the car) • [] Borla UEL headers (off the car) [1 Omni map 3 sensor [1 Delicious tuning - [] Ecutek tuning software (off the car) •[] AEM air / fuel gauge - [1 SB DXD Stage 3 daily clutch [1 HKS GT3-RS Turbo kit [] Hks s type oil cooler [1 Tein flex Z coilovers [1 Borla exhaust •[1 Brand new flywheel and clutch Clutch, flywheel and turbo brand new |
| The Following User Says Thank You to Romeodjan For This Useful Post: | Tcoat (08-10-2022) |
#12 | |
At this point there are so many unknowns that all the guess on the internet may never catch it.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | DarkPira7e (08-11-2022), soundman98 (08-11-2022) |
#13 |
Old school diagnosis trick: Spray some starter fluid into the intake. If it tries to start then you know it's a fuel problem. If nothing happens, you are no worse off.
| The Following User Says Thank You to blsfrs For This Useful Post: | FRSapex (08-13-2022) |
#14 | |
probably today will take out the engine and look if shafts are stand in propper way... |
| The Following User Says Thank You to Romeodjan For This Useful Post: | blsfrs (08-11-2022) |
| Car won't start - doesn't try to crank at all, but lights are working HELP | cdo221 | Issues | Warranty | Recalls / TSB | 28 | 06-06-2018 06:30 PM |
| Push start doesn't ignite? Had to try many times | hanabie | Issues | Warranty | Recalls / TSB | 4 | 07-09-2017 09:20 PM |
| Car doesn't start without fully charged battery. | frsq5 | Issues | Warranty | Recalls / TSB | 6 | 06-09-2017 09:59 PM |
| Car doesn't start, multiple "clicking" when trying to start | tracerit | Issues | Warranty | Recalls / TSB | 22 | 01-27-2017 02:56 PM |
| Engine doesn't start right away | Cajun | Issues | Warranty | Recalls / TSB | 1 | 02-04-2013 02:09 PM |
