Old 07-09-2017, 11:46 AM   #1
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Push start doesn't ignite? Had to try many times
Sorry if I missed that it has been discussed here.
These couple months I experienced that my push start button has been acting odd.
I pushed the start button and it just didn't ignite. It did not sound like it was a battery problem as it didn't sound like the car was trying to ignite but failed.
So I had to get out of the car, locked, returned to the car, and retried to push. It seemed to work that way.
Confused. TIA.
hanabie is offline   Reply With Quote
Old 07-09-2017, 11:55 AM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
The fob battery could be on its last legs as this can throw all sorts of issues.
Old 07-09-2017, 08:06 PM   #3
retoocs
Next time hold the fob next to the push button start, if it fires up, replace the fob battery.
retoocs is offline   Reply With Quote
Old 07-09-2017, 08:09 PM   #4
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
If the push start does ignite you may have problems.
Scrappydoo is offline   Reply With Quote
Old 07-09-2017, 09:20 PM   #5
steve99
look at the key symbol on dash if flashing yellow key fob battery is low or signal low
if its red then its not reading key code at all
also wiggle steering wheel to release electric steering lok pin sometimes it sticks
to start with flat fob battery , hold fob next to start button for 10 sec then press start with key fob next to start button
Car won't start. Limited with push to start. uEih Issues | Warranty | Recalls / TSB 22 01-06-2017 11:54 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Engine doesn't start right away Cajun Issues | Warranty | Recalls / TSB 1 02-04-2013 02:09 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
