FA20ToyBaru
Drives: Manual
Trans build
I just got the following installed:
DSS Axels DSS driveshaft Cusco LSD Cusco Ring and pinion Cusco collar PAR gears 1st-5th (assembled by jacks transmission) Verus Synchro kit Whiteline rear bushings kit Megan Racing adjustable trailing arms ISSUE: The problem is that I have a vibration once I hit 67-70mph on the highway. It is so strong that I figured something was broken. I have taken it afterwards to get an alignment and balancing of the two rear tires. I have also checked the tire pressure to eliminate all the things that I would know. Has anyone experienced this after installing any of these parts? |
Drives: Crapcan
DSS Al or carbon driveshaft?
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
Rust bucket enthusiast
May want to try unbolting the driveshaft, rotate the driveshaft 1/4 turn and bolt it back on to see if it gets better or worse.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | jcw99 (07-30-2022) |
FA20ToyBaru
Drives: Manual
We finished installing the 3" al driveshaft
FA20ToyBaru
Drives: Manual
Thanks for the input, we have looked at that and also run a stethoscope type instrument on the LSD, thinking maybe it was something in rotation...at this point..i am a little lost..thanks for checking in bro
Drives: Crapcan
DSS has admitted design fault in the AL driveshaft. The issue is the CS of the shaft is not high enough, though this only appears over 105mph. You likely have a balance issue. Mine vibrated at bit at around 65mph too but at track speeds you couldn’t see out of the rear view mirror. If it’s a street car have someone balance it again, if it is a track car call and talk with Kevin at DSS, if you have room in the trans tunnel they can do a 3.5” shaft reusing your joints that will fix it. Here’s a forum member who had failure on the dyno with one. https://www.ft86club.com/forums/showthread.php?t=148537
| The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (07-30-2022), DarkPira7e (07-30-2022), soundman98 (08-01-2022), Ultramaroon (07-30-2022), villainous_frx (07-30-2022) |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
+1 to what NoHaveMSG said, seems to be the most common issue with the 1 piece driveshafts to have vibrations that start around that speed and get worse the faster you go. This thread had some good ideas regarding it, perhaps some of it could apply to you - https://www.ft86club.com/forums/showthread.php?t=147489
Drives: 2013 frs base
@Fa20Toybaru: If you haven't already done so, reinstall your original DS and test drive.
| The Following User Says Thank You to blsfrs For This Useful Post: | NoHaveMSG (07-30-2022) |
Drives: Crapcan
Trans build
Also keep in mind if you are running a lower gearing in the diff it will lower the mph that it happens since it is the driveshaft speed that is causing it. DSS told me the CS was 110-115mph as in blsfrs’s thread. I was running a 4.3 and seeing it at 105.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (07-30-2022), soundman98 (08-01-2022) |
#10 |
FA20ToyBaru
Drives: Manual
I was testing, the install on all parts. I just got around 65-67 when I felt the initial vibrations. At the time, we had not done alignment and balancing. We were planning on doing it, just had not gotten to that step. After the initial testing, we did the alignment, and we checked tire pressure and balanced rear tires. The vibration was less, the car was able to get to about 90mph before the vibration started. We attempted to research, found that there had been issues with driveshafts causing vibrations, so I wanted to ask if anyone had similar issues, and what was the solution. I believe it might be because it no longer uses the center bearing that the stock driveshaft uses, but not sure, id rather ask and compare notes.
Still testing today, took everything apart yesterday, that is why I was unable to respond until today. I checked all bolts, marked to see if after driving if bolts loosen. We checked the rear DSS axels to see if that was causing issues. Everything, seems correct, we double checked everything still a strong vibration in the rear of the car at high speed. Trans shifts smoothly, I can feel the rear diff doing it job, the axels do not seem to be loose or pop out of the diff. It comes down to the tires or driveshaft |
#11 |
FA20ToyBaru
Drives: Manual
#12 |
Drives: FRS
Sorry cant answer your question, but how do you like your transmission? Any issues? How much power putting down for it?
#13 |
FA20ToyBaru
Drives: Manual
Thanks for sharing the information regarding the gearing. I had information regarding the MPH. I am just concerned about the vibrations, it is crazy...I am unable to even look out the rear mirror. The car will be on the track eventually, I am however testing it on the street. I am thinking about doing the home balancing of the driveshaft and seeing if that helps.
I am just stuck on where to start, I think it is just test and move, test and move...until it is right. Thanks for all the information and help |
#14 |
FA20ToyBaru
Drives: Manual
The trans alone is good, I am able to feel the grab. I wish I could be more specific, I have done alot to the drivetrain, so I am unable to tell you if alone it was the greatest things since sliced bread...however the transmission has not given me any issues. I am able to go through every gear, no grinding, it is loud, but it does make the car move a little quicker and reduce speed as well.
| How's the Manual Trans?? | BrZ_Good | BRZ Second-Gen (2022+) — General Topics | 37 | 12-05-2021 12:10 AM |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| Trans build for 400+- hp | Boris_Petrov | Engine, Exhaust, Transmission | 32 | 10-07-2019 04:22 AM |
| HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions | Corradooo | Engine, Exhaust, Transmission | 2 | 11-25-2017 07:16 PM |
| fs: Perrin trans mount and whiteline trans bushing | RWD_FR-S | Transmission and Driveline | 1 | 01-02-2014 05:34 PM |
