Old 07-28-2022, 02:04 PM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Coilover Ball Joint Bolt
Looking for some insight on this, it's limited to find online as far as I've found:
The singular, main bolt at the top center of the coilover I found to be a tad loose when I checked it (Was diagnoing a clunk noise from the front). I've looked online and found that ~40ft/lbs is an average torque spec for where that top bolt needs to be tightened down to, however I was wondering if there were any coilover gurus here that want to chime in on what the correct process is to get this at proper tightness. Should I just be torquing the bolt as is, or do I need to use a wrench to hold the assembly in place during this? Hoping someone might have some more insight than me, weird subject.
Coilovers: HKS Hypermax GTIV
Thank you
UPDATE: You're all super helpful, appreciate the responses.
scottryan is offline   Reply With Quote
Old 07-28-2022, 02:31 PM   #2
strat61caster
strat61caster's Avatar
Yes you will need to hold the damper body to prevent it from rotating.
I do 3 uga-dugas on an impact driver per vorshlags suggestion.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
norcalpb (07-28-2022), RToyo86 (07-29-2022), scottryan (07-30-2022)
Old 07-28-2022, 08:41 PM   #3
Grady
Grady's Avatar
I am sorry but the correct way is to hold it with an alien wrench and torque the nut with a torque wrench.
FYI I did use an impact on mine it is easier.
The Following User Says Thank You to Grady For This Useful Post:
Old 07-28-2022, 09:03 PM   #4
Code Monkey
Drives: Subaru BRZ
Also, set the compression/rebound adjuster in the middle before you use the impact.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Old 07-29-2022, 01:54 AM   #5
Compelica
Compelica's Avatar
Drives: 86 GT
Thank you
I have the same coilovers, how did you determine the clunk was due to a loose top bolt?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 07-30-2022, 06:12 PM   #6
scottryan
Financial Distress
scottryan's Avatar
Had a little clunk, tightened the top nut (I had a hunch because when I had them off, the ball joint felt loose, easy to spin the top) So I tightened to 40ft/lbs and zero clunk now.
The Following User Says Thank You to scottryan For This Useful Post:
Compelica (07-31-2022)
Old 07-30-2022, 06:30 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s pretty common with aftermarket camber plates. That or the sway bar end link is loose. I check mine multiple times a year.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
marco_mc22 (07-30-2022)
ball joint leak msaikhan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-01-2019 12:17 PM
Tie rod ball joint stuck Killianti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-19-2015 11:32 PM
Ball Joint Replacement, The fun way. FRSPacNW DIY (Do-It-Yourself) Guides 2 06-28-2014 04:04 AM
Front ball joint dimensions J-W Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-02-2013 06:31 PM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 02:16 PM
