| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2018 brz ts black edition
Tail light fuse keeps blowing
my tail light fuse keeps blowing, unless my vland headlights aren’t plugged in. any ideas on what might be the problem? i’m very inexperienced as far as electrical issues go this is my first one on any of my cars.
Drives: hyper blue
parking lamps or brake light fuse?
ProCrastinationConsultant
Well if the headlights not being plugged in stops blowing the fuse, I'd say it's the headlights.
friendly
Drives: 17' 86
Swap to OEM headlights, see if still blows. Ez.
Seek comfort in discomfort.
#5 | |
![]() If someone else swapped out your headlights, I suggest you take the car back to them and ask them to fix it. If you are the one that swapped out the headlights, I suggest you take it into a shop and ask them to fix it. BTW, which fuse keeps blowing? (position and amp) Good luck. |
#6 | |
thanks for your reply it’s a 10a fuse under the dash labeled “tail” i put them in myself and traded the oem headlights for these on facebook market place (not the best decision) i’ve asked 2 shops in my local area if they would look at it and they both said they don’t work on Subarus 🙄 |
Drives: hyper blue
pull the parking light bulbs in both headlights and try again. if it blows the fuse it is in the wiring of the lamp. If the fuse does not blow, try new bulbs.
| BRZ TAIL FUSE BLOWING | 404dare | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 04-13-2023 08:25 PM |
| Fuse #4 Taillights Keeps Blowing | epplecc | Electronics | Audio | NAV | Infotainment | 1 | 07-08-2021 06:12 PM |
| Tail/Fog/Plate light fuse keeps blowing | leevanf | BRZ First-Gen (2012+) — General Topics | 5 | 09-07-2018 08:09 PM |
| 4th brake light blew tail light fuse? wat? | Xaftos | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 11-20-2017 03:06 AM |
| Running light "Tail" fuse in foot well keeps blowing **Fixed** | paintdude258 | Electronics | Audio | NAV | Infotainment | 0 | 04-12-2017 03:59 PM |
