Drives: 2014 Argento Scion Frs
Normal knock correction and final multiplier
Hello everyone,i tried to search around and found nothing that could help me. i have a Turbo’d FRS on E85.
when it comes to Advance Multiplier and Knock Correction, what are the values that you should be worried? I know 1.0 for AM and 0 degrees knock correction is ideal. But does that mean i should worry if they dont stay there? I noticed that when i go about half throttle i start to get a couple degrees of Knock Correction in the low/mid RPMs. If i cruise at a somewhat constant speed for a while, AM starts to drop down to the .70’s.Not sure if i should worry, car feels perfectly fine to me. Thanks in advance |
Purist
Drives: 2013 FRS - Hot Lava
Im no tuning expert, but it sounds like the tune is expecting full E85 and getting E60-70. Knock is never good. I advise bringing it to a tuner and backing it off a bit.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
| The Following User Says Thank You to Westen86 For This Useful Post: | DarkPira7e (06-14-2022) |
Rust bucket enthusiast
Advance multiplier changing is concerning. Datalog and submit it here, you can upload to datazap.me
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
I have a flex fuel kit so it should be correcting it right? Im currently sitting at 80%. Sorry i should have clarified that.
Should i send a cruising log? Or a stop and go log? |
knock at cruise especially in high gears is common issue. A lot of tuners dont check the tunes on highway just on dyno so it gets missed.
can be fixed knock correction or flkc of -1 or less is fine , especialky if advance multiplier stays at 1. The occasional drop to 0.9 is ok but if its considpstently dropping to 0?7 or below probably worth looking at adjusting tune |
#6 | |
Drives: 2015 FR-S
#7 | |
Can be combination of all three to little fuel too uch tiing too little fuel on throttle transients ues high load in high gears tends to cause knock |
Update, it appears that my overpipe hitting the subframe was triggering the knock sensor. Advance multiplier has been at 1.00 for a couple of days vs before i simple drive to work (about 20 minutes) would make it drop.
There is still a few degrees of knock correction on partial throttle acceleration. My question is what should i be monitoring? Knock correction or ignition correction? Also what is FLKC and IAM? |
| The Following 2 Users Say Thank You to Sliver_bullet For This Useful Post: | DarkPira7e (06-17-2022), steve99 (06-18-2022) |
Drives: brz 2017 hksv2
both of them
flkc = ignition correction ap fine knock correction = ign correction ak knock both are relevant AM = advance multiplier IAM = initial advance multiplier, meanign the advance multiplier as set for right after startup, in oem tunes is set at 0.7 for example |
| Knock Correction | dholloway543 | Software Tuning | 3 | 11-05-2019 03:51 PM |
| Knocking without knock correction and knock correction without knocking | SorryTires | Software Tuning | 8 | 06-17-2017 03:57 AM |
| OFT Beeping, Knock Correction Blinking | Nothingman | Software Tuning | 5 | 01-25-2017 03:07 AM |
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 10:09 PM |
| Knock Correction Maping | Toyota John | Software Tuning | 12 | 08-06-2014 06:44 AM |
