Old 06-15-2017, 10:18 PM   #1
SorryTires
SorryTires's Avatar
Drives: 2013 FRS
Knocking without knock correction and knock correction without knocking
So I've been getting quite a bit of low rpm/load knock like 20+ knock occurrences in a five minute drive. Almost all below 3000rpm and below 0.4g/rev load. Very few of these knock occurrences cause any knock correction and AM is pinned at 1 the whole time does that just means they are small knocks? is it normal to have so much knock but not have any knock correction?
Also sometimes knock correction happens without a knock signal. Is it normal to have knock correction happen when its not immediately preceded by a knock signal? or is it an error in the log?
SorryTires is offline   Reply With Quote
Old 06-15-2017, 10:44 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Opening up the rom and looking at the data will give you an inidcation of the logic.
Old 06-16-2017, 12:09 PM   #3
SorryTires
SorryTires's Avatar
Drives: 2013 FRS
That explains why there is usually no knock correction but I still don't get why there would be knock correction when it doesn't detect knock
Old 06-16-2017, 04:06 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
What are you using to log, I'm assuming EcuTek? Don't forget that unless the knocking signal is the exact moment the logging polls that parameter it won't show. Also, not all instances that could trigger the knock sensor will retard timing. That and @Wayno's post answers the question.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-16-2017, 04:32 PM   #5
SorryTires
SorryTires's Avatar
Drives: 2013 FRS
Yes I'm using ecutek. So there's potentially a bunch of knock that isn't shown as a knock signal because it happens between the log points? That significantly reduces the usefulness of logging knock signal
Old 06-16-2017, 05:57 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes, it's useless. I logged it once, but it's not clear what it's logging so I've not used it since. It may not even be filtered.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-16-2017, 09:03 PM   #7
phrosty
OP2 logs with such a high frequency that you're not going to miss any knock.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 06-16-2017, 09:35 PM   #8
steve99
Not sure if the OPis logging raw knock sensor input, if so its likely theirs a lot of signal processing done by ecu to determine if its a valid knock input or just noise probably looks at crank position ignition etc and applies a lot of filtering before its even decalred a valid knock signal then processed through the stuff wayno posted.
Old 06-17-2017, 03:57 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
If we can't determine if pre/post processing or have any control over the knock control system it's not really worthwhile logging.
.: Stealth 86 :.
Kodename 47 DJ:
mid pipe knocking turtlefeeder Engine, Exhaust, Transmission 74 07-19-2020 12:09 AM
Kodename 47's Knock Correction Tool Kodename47 Software Tuning 15 02-12-2017 06:24 AM
OFT Beeping, Knock Correction Blinking Nothingman Software Tuning 5 01-25-2017 03:07 AM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Knock Correction Maping Toyota John Software Tuning 12 08-06-2014 06:44 AM
