Old 01-20-2017, 03:33 PM   #1
Nothingman
Drives: 2013 Scion FRS
OFT Beeping, Knock Correction Blinking
I just flashed to the STG 1 93oct earlier this week, when driving home from work today. I got off the freeway, and once I hit the off ramp, my OFT starting beeping and Knock Correction was blinking. Can anyone shed some light as to what is going on? I'm super green when it comes to tuning and/or the terminology for that matter.
Thanks!
Nothingman is offline   Reply With Quote
Old 01-20-2017, 03:38 PM   #2
phrosty
Sounds like car was knocking. Post a log if you want better info, not enough here to go on.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 01-20-2017, 06:00 PM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Thanks!
Looks like you may have inadvertently set up a tuner alert for knock correction while you were going through the menus. Go to Diagnostics, My car, and then Tuner Alert. Just disable each of the tuner alerts (you will needs to scroll down to see the 2nd and 3rd).
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Nothingman (01-20-2017)
Old 01-20-2017, 06:49 PM   #4
Nothingman
Thanks Shiv! I purchased it used so it must have been set like that already. Much appreciated!
Old 01-23-2017, 04:33 PM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i like beeping
Old 01-25-2017, 03:07 AM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Read the threads in @steve99 signature. They will help you understand the basics and what stuff means. While its probably nothing beyond a minor knock event it is good to learn the difference so you know when there is a problem
10 Series Beeping Abraxus Scion FR-S / Toyota 86 GT86 General Forum 6 08-05-2020 07:13 PM
Kodename 47's Knock Correction Tool Kodename47 Software Tuning 15 02-12-2017 06:24 AM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Knock Correction Maping Toyota John Software Tuning 12 08-06-2014 06:44 AM
CEL blinking in my new car 86Kenshin Issues | Warranty | Recalls / TSB 16 06-02-2014 10:36 AM
