Old 06-01-2022, 09:32 PM   #1
STMike1
Drives: 2019 BRZ
2019 BRZ - rear clicking question:
Hi -
I hear a clicking noise at this point only when under power starting out in first gear and reverse gear (when there is significant torque being applied I guess).
Here's the baselines:
-100% stock, except it's on new Toyo Proxes Summer tires (similar to stock tires
-6 speed manual
-No AX or track events on BRZ
-No clutch drops and minimal hard 1 to 2 while cornering
-I do enjoy inducing mild oversteer on a frequent basis
The click isn't bad or terribly annoying, just getting worse. Are there likely culprits for this issue? What can I potentially expect?
THANKS
Mike
STMike1 is offline   Reply With Quote
Old 06-02-2022, 06:45 AM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Try checking your axle nuts: retorque or replace them. Common issue on this platform.
Google "FRS BRZ Axle Click" to verify if it's the same noise.
EndlessAzure is offline   Reply With Quote
Old 06-02-2022, 12:39 PM   #3
STMike1
Drives: 2019 BRZ
Thanks
Old 06-02-2022, 12:41 PM   #4
STMike1
Drives: 2019 BRZ
Oh any symptom to look out for for an actual axle failure?
Old 06-09-2022, 08:41 PM   #5
EndlessAzure
Wheels for Brains
Leaking boots or axle play
Old 06-29-2022, 04:09 PM   #6
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
I had the same problem OP. Turns out it was my axle nut and the scissor jack moving around in the trunk. Hope this helps anyone in the future.
scion fr-s is offline   Reply With Quote
Old 11-15-2022, 06:17 PM   #7
STMike1
Drives: 2019 BRZ
Hey just recuscitating this old topic:
I never got my axle nuts looked at. The problem diminished with cold weather and I procrastinated. What kind of problems can loose axle nuts create? I worry I may be costing myself a bunch of money unnecessarily.
Clicking noise from the rear Seiryuu Issues | Warranty | Recalls / TSB 18 05-17-2020 08:07 PM
Clicking Sound From Rear (Axle?) gonzo Issues | Warranty | Recalls / TSB 9 02-09-2020 12:26 PM
2019 BRZ Fog Light Question Lebby83 Cosmetic Modification (Interior/Exterior/Lighting) 10 08-05-2019 02:12 PM
Question about warranty work and steering clicking at low speed JM197 Issues | Warranty | Recalls / TSB 5 07-20-2016 10:55 AM
Clicking coming from rear.. HillCountryGuru Issues | Warranty | Recalls / TSB 3 03-22-2013 12:05 AM
