Old 05-02-2019, 10:02 PM   #1
Seiryuu
Drives: ZC6
Clicking noise from the rear
So I searched around, google, youtube and forum, on this plastic-sounding "clicking" (well, more like a box of capsule pills being shaken once to be accurate) noise that seems to be coming from the rear that I recently just noticed. From the research, signs point to CV joint so I went to take a look at them but they were very clean and doesn't seem damaged. Looked up videos but none of the sounds are similar.
So I went out for a drive to record the sound to show you guys. It took over 45 minutes of driving to finally managed to record a few seconds of it. It's not consistent and not easy to replicate. How it seems to come out is if I step on the throttle while the car is already in gear and moving. Here's the video:
It's only within the first 25 seconds. You can hear it ONCE at the 5 second mark then once again at the 13 second mark. Only at the instant when I gave it throttle. It's much more audible in person than the video suggests.
Maybe this is actually normal and the car have actually been doing this like all the weird rattles and clunks this car seems to have but I finally picked up on this one.
If you guys can take a listen and let me know your thoughts and point me in the right direction, that would be greatly appreciated. Thank you!
Seiryuu is offline   Reply With Quote
Old 05-02-2019, 10:44 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
I watched the vid with headphones, I didn't hear anything abnormal.
Even at the 5 and 13 second mark. Maybe it's your rear deck? There is a TSB for it.
other than that I don't know.
Old 05-02-2019, 10:52 PM   #3
Seiryuu
Drives: ZC6
Oh I guess I should mention it's not really "clicking" (as in a continuous sound) but only at the instant I step on the throttle and then goes away until I can repeat it again. I guess it's more like a loud "tick" from a clock. Oh yea, and I've checked the rear deck, under the trunk, all the plastic bumper caps/plugs and they were all snug in place as well.
Old 05-02-2019, 11:34 PM   #4
RayRay88
Drives: 2017 86 860 Special Edition
I couldn't hear your noise in the video but, I too have a similar metal clinking.
My guess is it's the exhaust hitting something (happens at high load stabs on the throttle meaning a lot of movement in the engine components).
Out of curiosity what mods do you have (spare no part please).
I see it's a Kouki BRZ, I have a Kouki 86 too.
RayRay88 is offline   Reply With Quote
Old 05-03-2019, 02:36 AM   #5
Seiryuu
Drives: ZC6
My car is actually completely stock.
I'm going back to listening to the video now after walking away from it... and I guess it's so faint, it could just be passed off as video "noise" (sounds like an audio "scratch"). So even if you could hear it, probably won't be able to pick off what it could be since it's so vague.
Okay, different video but same day.
Very short. I think you can hear the mechanical "tick" a couple of times at the start (1 -3 seconds) and another "tick" at the 12 second mark. Every time it's when I stab the throttle.
Old 05-03-2019, 08:28 AM   #6
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I can't hear anything abnormal.
Trueweltall is offline   Reply With Quote
Old 05-03-2019, 09:25 AM   #7
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
May not be the same thing but I throw it out there anyway.
https://www.ft86club.com/forums/showthread.php?t=131932
22R
22R is offline   Reply With Quote
Old 05-03-2019, 12:53 PM   #8
extrashaky
Drives: 2014 BRZ Limited
I hear it. I would check under your seats and in the tray under the cargo cover for something loose shifting and clicking against something metal when you hit the accelerator like that. If it really bothers you, I would also get underneath and wiggle the exhaust to see if it's knocking against something.
Otherwise I would ignore it. Turn up your radio.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
Seiryuu (08-28-2019), smoke86 (05-04-2019)
Old 05-04-2019, 09:51 AM   #9
smoke86
Drives: smoke Toyota 86
Get a Perrin 2.5 resonated CBE I love mine!! As for the clicks, is your rear license plate frame tight?
smoke86 is offline   Reply With Quote
Old 05-04-2019, 02:47 PM   #10
norcalpb
norcalpb's Avatar
Did the emergency trunk release come out of its slot inside the trunk?
Old 05-04-2019, 08:08 PM   #11
edwardl
Drives: 2018 BRZ
I have a click in my rear but it's a lot higher pitched than yours. My research has concluded it's the axle nuts which are apparently weak on this cars and new ones should fix it.
edwardl is offline   Reply With Quote
Old 05-04-2019, 11:49 PM   #12
Sgaldi
Sgaldi's Avatar
Drives: 2018 Subaru BRZ Premium
These cars make so many noises, fun car buy annoying as fuck
Sgaldi is offline   Reply With Quote
Old 05-22-2019, 10:01 PM   #13
khrono
Drives: 2015 Subaru BRZ
I got the same tick/click noise. Extremely noticeable when in 1st in a parking garage. The noise goes away after car settles. If I accelerate again, then it comes back fainter. I've heard that it was the axle nuts, but I haven't bothered to take off mine and replace it.
I have 95k miles and I feel like the noise has stayed the same. It hasn't been louder or different. If the noise changes or the car handles differently then I will try to fix it.
Maybe someone that fixed the axle nut and had the clicking go away can comment?
khrono is offline   Reply With Quote
Old 05-23-2019, 12:17 PM   #14
RayRay88
Would this clicking/axle nut issue be present on a 2017 car? I've had this issue as far back as last year. It's driving me nuts. I went underneath and couldnt find anything rubbing or close in terms of exhaust, bolts, powertrain etc. The only thing that had play was my driveshaft. I can clock it about an 1/8 of a turn back an forth. Is that normal lash/play for a driveshaft?
Clicking / Ticking Rear Noise shellslinger Issues | Warranty | Recalls / TSB 19 07-20-2017 09:40 PM
Rear end clicking noise after spring install Nhil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-16-2017 09:44 PM
Clicking noise from rear end when parking with hand brake engaged JSanders Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-04-2016 05:20 PM
clicking noise from drivers side rear CARBONGT86 CANADA 11 08-23-2015 06:58 PM
Clicking noise from left rear control arm? pghfan19 Issues | Warranty | Recalls / TSB 7 07-29-2014 06:48 PM
