Old 05-31-2022, 01:47 AM   #1
nerve86
Drives: ZA1JA03N
Look for the ZA1JA03N complete RomRaider Editor Definition definition file.
I found ZA1JA03N my RomRaider Editor Definition is incomplete. Searched the forum and there is no, only ZA1JA01g.
thanks.
nerve86 is offline   Reply With Quote
Old 05-31-2022, 06:15 PM   #2
steve99
see here
https://www.ft86club.com/forums/show....php?p=3060187
Old 06-01-2022, 07:04 AM   #3
nerve86
Drives: ZA1JA03N
Can I modify the calid in the xml of A01G to be 03N?
Old 06-01-2022, 07:11 AM   #4
nerve86
Drives: ZA1JA03N
I want to edit the stock 03n and then use it for ecutek, not the 03n of oft based on 01g, can I directly modify calid=03n to use it?
Old 06-01-2022, 07:41 AM   #5
nerve86
Drives: ZA1JA03N
@steve99, I modified the xml calid=03n of A01G, opened the rom, and the table data displayed in it was wrong.
Old 06-02-2022, 05:33 AM   #6
steve99
Are you using romraider and oft roms or ecutek ?
oft A03N will be based on a substitute rom and that will confuse ecutek
if ecutek use ecuteks editor if you want to edit genuine A03N roms
Old 06-02-2022, 05:38 AM   #7
steve99
post up tje rom your trying to edit here ill jave a look
Old 06-02-2022, 03:35 PM   #8
nerve86
Drives: ZA1JA03N
ecutek is missing some table definitions, such as overrun, I use romraider to edit the missing table in the stock ROM, and then use ecutek to edit it.
Old 06-02-2022, 03:38 PM   #9
nerve86
Drives: ZA1JA03N
But I can't find the complete definition file of the romraider for the stock rom of A03N.
Old 06-02-2022, 03:52 PM   #10
nerve86
Drives: ZA1JA03N
this is the file i use,
genuine A03N roms,and RR_ZA1JA03N.xml,Incomplete definition, like my first post.
03n.zip
Old 06-02-2022, 04:24 PM   #11
nerve86
Drives: ZA1JA03N
After modifying RR_ZA1JA01G.xml, an error is displayed.
Old 06-02-2022, 07:49 PM   #12
steve99
Attachment 212375
Attachment 212373
Attachment 212374
OK my trick with definitions only works with OFT roms as their A03N tunes are actually based on A01G roms
you could just use A01G in your car as a substitute for the A03N rom.
There are no romraider definitions for genuine A03N roms
however easier to just use ecutek if you have it
Ecutek has all the tables you need in the A03N they are just called different names
The idle overun tables you want are called
"Ignition Timing Idle" there is about 6 tables defined more than romraider in A01G they are under Ignition timing folder in ecutek they are fully defined so just edit your A03N rom in ecutek
Old 06-03-2022, 02:32 AM   #13
nerve86
Drives: ZA1JA03N
Thank you for your reply!
ecutek prevents me from flashing the A01G.
If I flash the A01G with ecuflash, I will lose the ecutek license.
Is there a way to transplant the rr definition of A01G to 03N?
Old 06-03-2022, 07:42 AM   #14
steve99
sent you private message
nerve86 (06-07-2022)
2019 86 ZA1JN01A Definition file Whit_grf Software Tuning 3 03-19-2022 12:27 AM
ecuflash definition file help Plumpkibbles Software Tuning 1 10-13-2018 05:19 AM
Romraider cannot read definition (OFT FlexFuel) yelsew Software Tuning 2 05-24-2018 06:32 PM
RomRaider help? ECU definition cannot be found even when present? Xaftos Software Tuning 9 09-27-2017 06:13 PM
Edit OFT Definition for RomRaider blackspike Software Tuning 7 02-13-2016 03:18 AM
