Old 02-12-2016, 11:48 PM   #1
blackspike
blackspike's Avatar
Drives: Toyota GT86 racing red, Aero
Edit OFT Definition for RomRaider
Hello,
i want to edit the ZA1J700I Stage 1 ROM but in the current OTS v2.072 folder is only the ZAJA01I definition.
Is it ok just to change these two parameter with an xml editor to use the A01I definition with the 700I ROM in RomRaider?
I have sent an email to sales@openflashtablet.com but unfortunately still no answer.
Need the file really quick because today i have time to test the ROM (it's saturday 5:46 early morning in Austria).
Thank you guys!
Edit: If i do so and compare the 700I ROM wit the A01I ROM the only differences are the second checksum correction.
Looks right for me...
For crosscheck i have changed the ID in the 700D ROM into 700I - get lot of errors when loading it in RomRaider.
blackspike is offline   Reply With Quote
Old 02-13-2016, 12:12 AM   #2
steve99
Are you using OFT to flash tunes ?
@blackspike
If you using oft that wont work you need to do a bit of calid hacking inside an A01I rom to make the oft think its an 700I rom
post up your 700I rom here as i need some info out of it to fool the oft.
Then I can make you a A01I rom that looks like a 700I rom to the oft and a hacked A01I definition that will edit that rom.
Old 02-13-2016, 12:25 AM   #3
blackspike
blackspike's Avatar
Yes, my OFT arrived yesterday!
Old 02-13-2016, 12:30 AM   #4
steve99
ok post up your stock 700I rom you can download it fron oft if you have married oft to car
it will be called ZA1J700I.ori i dont have one of those
alternatively if you are ok with a hex editor i can email you the instructions
Old 02-13-2016, 12:36 AM   #5
blackspike
blackspike's Avatar
Where do i upload it? Can i send it to you per e-mail?
Old 02-13-2016, 12:36 AM   #6
steve99
The reason you can do this is because A01I is compatible with 700I , the A01I is a later rom with some idle and bug fixes
Old 02-13-2016, 01:14 AM   #7
blackspike
blackspike's Avatar
I can upload the 700I file i edited with the A01I definition (tarned like i said in post 1) to my OFT.
So maybe i don`t need your file?
I`m not sure if everything is allright with the ROM but it looks ok:
EDIT: I use the files from steve99 now to be sure!
Old 02-13-2016, 03:18 AM   #8
steve99
yes safer to use defs i sent you they have extra tables as well
Using RomRaider to edit tunes ( ROM) files OFT and non- OFT steve99 Software Tuning 56 11-18-2020 08:41 PM
Definition of rice? Hot Lava Off-Topic Lounge [WARNING: NO POLITICS] 42 05-30-2014 03:41 AM
ECU table functions and definition of tables brn12345 Software Tuning 7 11-14-2013 08:45 AM
E46 M3 photo/video shoot by Project Definition DTMAUTOBODY Other Vehicles & General Automotive Discussions 0 06-18-2013 07:00 PM
AS1 Definition? nixeighty6 Scion FR-S / Toyota 86 GT86 General Forum 93 01-12-2012 01:56 AM
