Old 05-28-2022, 10:21 AM   #1
OfficeLinebacker
Drives: 2019 Toyota 86 Base AT
Question Auto Trans slipping in Sport mode 1-2 and 2-3?
So I got this car last year and this year I started driving it hard on back roads and stuff a lot. It was originally on its factory fill of ATF less than 50k miles, though I flushed it with synthetic and it didn't fix it.
Last week it got really hot (90+) while I was driving and the car started shifting funny. Normally the shift light turns on for a split second and the shifts are crisp. But the car started over revving or something, and the revs would drop a ton on shift. When the car would cool down, it would get better. But it gradually got worse so I took it out of sport mode and drove it normally until I could get the trans flushed.
The A/T Temp light never turned on on the dashboard.
I had a similar issue in a previous car and a trans flush using synthetic fluid fixed it, so I had the trans flushed. However, it's still doing it, even when not super hot. Basically I can reproduce it now by pulling off on the shoulder of the highway, putting the car in Sport Mode, then waiting for a gap in traffic and flooring it. It's noticeable from 1-2 and from 2-3 it's really bad. Like the light turns on and it kind of revs, dies, revs, dies, then finally shifts and the RPMs dropped.
I'm worried that I burned out the clutch packs or something. Does anybody know what might be going on?
OfficeLinebacker is offline   Reply With Quote
Old 05-28-2022, 01:13 PM   #2
86TOYO2k17
Drives: 2017 toyota 86
How did you “flush” it? (hopefully not a real “flush”)
What fluid did you put in specifically?
What mods do you have?
An atf cooler would have been wise before beating on her.
Old 05-28-2022, 03:50 PM   #3
humfrz
Maybe the Automatic Transmission Control Module is acting up?
atf, auto, auto trans
Auto- trans. Don't be a jerk. Try SNOW mode. notout86 Engine, Exhaust, Transmission 22 08-31-2019 01:48 PM
Auto Trans Feels like it is slipping... Fett4Real Issues | Warranty | Recalls / TSB 19 01-16-2014 10:02 PM
DIY Auto VSC Sport and AT Sport Mode Seattle944t DIY (Do-It-Yourself) Guides 0 09-08-2013 05:02 PM
Cruise control with Sport or VSC Sport mode notout86 Scion FR-S / Toyota 86 GT86 General Forum 12 08-29-2013 06:50 PM
Keeping it in Sport Mode (auto tranny) Burrcold Engine, Exhaust, Transmission 49 07-25-2013 03:40 PM
