Old 11-16-2012, 08:00 PM   #1
Burrcold
Drives: Subaru BRZ Limited
Keeping it in Sport Mode (auto tranny)
As most who own the auto tranny know, sport mode truly makes this car worthy of a fun sporty car. The problem I'm finding, is that when I don't set in sport now, the drive is pretty boring.
Even in traffic I find sport mode to be better, since the car is not constantly changing gears as you slow down/speed up (holds the current gear long enough to keep traffic driving more tolerable).
So question; is it bad to turn it to sport mode every time you drive? How big of a difference will fuel economy be (assuming you're not smashing on the gas ever where)? Bad for any part of the engine and/or tranny?
At this point I'm finding myself turning it on immediately when I get in the car. In fact, I wish it would just stay in this mode.
Thoughts?
Old 11-16-2012, 08:15 PM   #2
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I only use sport mode when on the freeway or back roads as I like the response when I need it. Around town it's in standard auto mode.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
The Following 4 Users Say Thank You to russv For This Useful Post:
frsguy707 (11-17-2012), liquidsky44 (11-17-2012), qganja (03-02-2014), Style (11-18-2012)
Old 11-16-2012, 08:20 PM   #3
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
I cant imagine it does anything except waste more gas. Im not always driving like im crazy so i turn it off and use it sparingly...
you cant always want it to shift like mad when you're commuting to-from work and stores... at least i am not.
but its hella' fun to save that for the wknds when im out on my drives !!
rikdrt1 is offline   Reply With Quote
Old 11-16-2012, 08:21 PM   #4
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
im always in manual mode, better than both...
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
The Following 7 Users Say Thank You to carbonBLUE For This Useful Post:
Ammonia (07-07-2013), autobrz (07-10-2013), GT 86 Brah (07-10-2013), Guff (11-17-2012), jamesm (07-07-2013), neutron256 (11-17-2012), Splat (07-10-2013)
Old 11-16-2012, 08:27 PM   #5
mRdeMs83
mRdeMs83's Avatar
Drives: Argento FR-S 86
I am some what afraid of driving with it off. Should I be? Like I'm not knowing what to expect on a A to B commute. I drive my work truck all week and my 86 about two days in between weekends where I drive it more. The roads around where I live are FM country roads without much through traffic. What ya think?:confused:
Sent from my EVO LTE using Tapatalk 2
mRdeMs83 is offline   Reply With Quote
Old 11-16-2012, 08:29 PM   #6
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
You are not going to damage the transmission. But mileage may drop slightly. The TCC is pretty aggressive on this tranny no? So I wouldn't imagine slippage losses will be severe enough to really ruin mileage.
Coheed is offline   Reply With Quote
Old 11-16-2012, 08:39 PM   #7
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I find the car to be fun in sport or non sport mode. But its "spirited" driving i'll leave it on sport mode or play around with flappys/stick.
Old 11-16-2012, 11:40 PM   #8
whataboutbob
AutoX-10/10ths every run
I use the sport mode almost all of the time, except when I get into the carpool lane on the freeway and put the cruse control on (it turns off automatically when cruse is on).
BTW, I've been able to get 36.7MPG AVG on a 40mile trip to work with the cruse on and doing 65MPH. Not as much fun, but that's good mileage IMO.
Build thread:Here
Old 11-17-2012, 12:02 AM   #9
Captain Insano
I only use occasionally when I am driving for fun. I cant imagine leaving it on all the time will hurt the car or they would not have released it from the factory with sport mode.... also you have warranty just in case so have fun!!
Old 11-17-2012, 12:30 AM   #10
serialk11r
Drives: '06 AM V8V Coupe
It can't hurt the transmission because the car is programmed to match the shifts correctly and everything in manual mode. Gas mileage can be better or worse depending on how you drive, but most people don't know how to save gas better than the automatic transmission (it's not hard to beat it though). Outperforming the auto basically comes down to staying in higher gears instead of downshifting every time your foot jabs the throttle a little too hard, and possibly shifting out of 1st sooner (I haven't seen how these automatics behave).
Old 11-17-2012, 02:39 AM   #11
KI_ZN6
KI_ZN6's Avatar
Sport mode is safe to use everyday as the car's transmission is well-designed (borrowed the layout from an ISF transmission except the FR-S is 6 speed and not 8 speed). The car's engine also has a rev limiter, so you cannot really hurt the engine or transmission. I only use sports mode when I need to pass someone or during spirited driving XD
KI_ZN6 is offline   Reply With Quote
Old 11-17-2012, 11:45 AM   #12
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
It's actually most likely the A960E from the IS250 according to Kaizen Factor.
Subie is offline   Reply With Quote
Old 11-17-2012, 01:28 PM   #13
carbonBLUE
Reverse Burnouts
its and upgraded A960E its what they will be using in the 2014 IS250, It's def stronger and faster, not to mention smarter, the tech and its supporting parts are from the ISF
solenoids arent as great as the ISF but def better than whats in the IS250(solenoids depict how fast the transmission shifts fyi for those who dont know)
(wont forget you)
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
Freeman (11-17-2012)
Old 11-17-2012, 01:51 PM   #14
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
If you are willing to use up more gas all the time, go for it. It also defends on where/what speed you drive most of the time. I live/work on an Air Force base with a speed limit of 35mph and at that speed sport mode didn't want to shift past 3rd gear most of the time, which killed my mpg. A lot of the time I'll put it in sport mode for entering the freeway or for fun, spirited driving. When I reach cruising speed I'll switch it off (of course when you engage cruise control it shuts off automatically.)
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 09:23 PM
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 02:40 AM
Is the auto tranny from a isf? WolfsFang Engine, Exhaust, Transmission 6 08-25-2012 09:25 PM
Delivery day. To sport mode or not? Oilers99 Scion FR-S / Toyota 86 GT86 General Forum 5 06-21-2012 06:50 AM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
