| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: 22 BRZ
I recently installed some 18x9.5+43 with Hankook Ventus V12 Evo2 (245/35/18). With some BC racing coilovers from my previous Gen 1.
This is my first time running a wider tire set up on one of these cars. The largest i've run in the past where 225/40s on a 9.5. The car feels unstable on the highway and im constantly fighting it to keep it straight in the lane to the point where it just feels unsafe almost floaty like a sway. I took the car in for an alignment since it felt like the toe might have been out in the rear but that did not seem to change much. I know tramlining can be an issue with wider tires that are lower profile but i feel like this is a pretty common set up for these cars and i really haven't seen other people complaining about this. Anyone running a similar setup what has your experience been? Suspension is all stock arms and the front camber plate on the coilovers are zero out (so no excessive camber other than the nature camber from the modest drop). I did install the coilovers and wheels the same day so ill be swapping the wheels back to stock to see if it is in fact tramlining. [IMG] [/IMG]
Rust bucket enthusiast
If the car has any toe out, the larger width is going to exacerbate the tramlining. Have you gone to an alignment shop after installing the coilovers to get everything checked?
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
Drives: 2015 Scion FRS Release Series 1.0
Alignment was after the coilovers, right? Do you have a copy of the alignment results?
ProCrastinationConsultant
can you post the alignment printout?
| The Following User Says Thank You to soundman98 For This Useful Post: | timurrrr (05-29-2022) |
Drives: 22 BRZ
So i feel like an idiot. So i assume the place where i got my tires mounted would set the psi to somewhat oem. However every tire was above 50 psi and one of the rears was probably around 60 or 70 psi... which explains why it felt so washy....
Dropping it all down to 35 completely fixed the issue. Car feels great now.
| The Following 10 Users Say Thank You to ZX88 For This Useful Post: | Burrz (06-01-2022), DarkPira7e (05-28-2022), jongers (05-28-2022), Midnightsky (05-27-2022), Ohio Enthusiast (05-28-2022), PBR (05-28-2022), soundman98 (05-28-2022), Tcoat (05-27-2022), timurrrr (05-29-2022), Wally86 (05-31-2022) |
#6 | |
Drives: 2022 BRZ WRB
| The Following User Says Thank You to Midnightsky For This Useful Post: | soundman98 (05-28-2022) |
#7 | |
Drives: '22 BRZ
| The Following User Says Thank You to mr.whiskers For This Useful Post: | Wally86 (05-31-2022) |
#8 | |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
| The Following User Says Thank You to 2020BRZtS For This Useful Post: | Wally86 (05-31-2022) |
#9 | |
Drives: 22 BRZ
| The Following User Says Thank You to otter For This Useful Post: | Wally86 (06-01-2022) |
| Tags |
| 2022 subaru brz, brz, te37 5x100 |
| Spare tire for a week now car feels floaty / traction light goes off a bunch | subaruslow | Issues | Warranty | Recalls / TSB | 23 | 06-16-2021 01:20 PM |
| Performance package wheel/tire weight vs. regular wheel/tire combo | qqzj | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-26-2019 01:27 AM |
| JUST REPLACE THE NEW STEERING WHEEL/ FEELS SOOO GOOOD | felix_tanggg | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 05-20-2019 11:12 AM |
| car feels funny after changing to summer tire/wheels | theman233 | Issues | Warranty | Recalls / TSB | 4 | 04-02-2017 01:48 AM |
| Unstable feeling | Toyobaru808 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 06-28-2013 11:06 AM |
