Old 06-01-2021, 02:51 PM   #1
subaruslow
Drives: subaru
Spare tire for a week now car feels floaty / traction light goes off a bunch
So unfortunately I had to drive on the factory spare for a week or 2. Lots of bumpy hilly roads. I've noticed now that I got back on 4 regular tires the rear axle or back end of the car feels floaty and the traction control light is going off on any bump and seems to be accompanied by the floatiness. It just doesn't feel right.
Is there something that can be recommended to check with the rear axle or diff? I've heard of abs sensors causing problems but I don't see how this would display the weirdness in the back of the car.
Any ideas or advice?
car is stock besides tires and pp struts and shocks.
subaruslow is offline   Reply With Quote
Old 06-01-2021, 03:02 PM   #2
Stupid Question #1: have you checked the pressure of your new tires?
Old 06-01-2021, 03:08 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Stupid Question #2: Are all four tires identical?
Dadhawk (06-01-2021), norcalpb (06-03-2021)
Old 06-01-2021, 03:45 PM   #4
Stupid Question #2A: Including wear, or at least close to the same wear?
Ultramaroon (06-01-2021)
Old 06-01-2021, 07:10 PM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Stupid question 3: did you check the spare's pressure before putting it on?
Stupid question 3b: did you install the spare on the rear axle?
Stupid question 4: what caused the need to install the spare?
The Following User Says Thank You to RZNT4R For This Useful Post:
Old 06-01-2021, 07:59 PM   #6
subaruslow
Drives: subaru
I dented the inside lip of the rim on a shit pothole, not the outside go figure. All tires are the same michelins 4s i believe they are called. Spare tire went on the front right not the rear. I did check the tire when it went on but I haven't checked all 4, hmm probably pretty stupid on my part I just figured I'd get a dash light if it was really low. I did check the spare tire air and aired it up before it went on.
I wish I could have done things differently but at the time it was our only working car and I had trouble getting it into a tire store. Now I'm kicking myself as I have never driven on a spare that long. Sorta a low point.
Anything that could be checked with the rear diff / axle? Now I'm afraid to hustle it around.
- I also forgot to mention the tire store f'ed up 3 of my wheel studs on front left and had to replace them before I got the car back.
Old 06-01-2021, 08:18 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Stupid question 5: Did you have the alignment checked after this damage?
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Overdrive (06-01-2021), soundman98 (06-01-2021), Ultramaroon (06-01-2021)
Old 06-01-2021, 10:39 PM   #8
Ultramaroon
not playing cards
Oooo.... @NoHaveMSG is on point! I'll take Get Bent for 600, Alex. Spare tire didn't hurt anything. You mounted it up front so good on you.
Dadhawk (06-02-2021), NoHaveMSG (06-01-2021), Overdrive (06-01-2021)
Old 06-01-2021, 11:20 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Well I was pretty much bread crumbed into it
Old 06-01-2021, 11:37 PM   #10
Ultramaroon
not playing cards
It still could be a severely overinflated tire but dem breadcrumbs doe.
Old 06-02-2021, 05:13 PM   #11
subaruslow
Drives: subaru
Ok I guess next thing is to take her in for an alignment. I didn't really consider that as the car seems to have as much or more trouble on rough straight aways than corners but my thinking i would notice alignment issue more on corners maybe flawed.
I just hope there is nothing else funky going on, the roads I drive are so damn awful I mean the worst of the worst in the state.
Old 06-02-2021, 07:14 PM   #12
RZNT4R
Go for the alignment, you hit a pothole hard enough to bend a rim...
Alignment is way more sensitive on the flat and straight. On-center feel is incredibly easy to get smashed out by any sort of impact.
Old 06-02-2021, 07:34 PM   #13
Grady
Grady's Avatar
When you say 4 regular tires are they the same tires or did you just replace 1? Did you buy new, used, old tire? If you have different wear on the back that will cause issues. If you have an old tire it will be hard and have poor traction.
Old 06-03-2021, 12:02 AM   #14
subaruslow
Drives: subaru
They are all 4 michelin's I put on a new a year or so ago, the tire was not damage so it went back on once I got a new rim. Pressure's are all good.
To me it feels as if sometimes after a bump the car keeps undulating more than it should / use to. The back of the car is moving way more than it should.
Today after a spirited drive i have now developed an odd whirring sound at low speed, i'm definitely thinking there is something else other than alignment wrong now. Maybe I'll get lucky and the valvetrain will blow up and I can just light a match on the car while sitting in it.
things are not going well for me.
wheel bearing?
Performance Package spare tire vs. regular spare JeremyR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 67 09-22-2022 09:36 PM
Car feels better and more natural with hold traction off but why jflogerzi Tracking / Autocross / HPDE / Drifting 14 11-23-2020 01:09 PM
car feels funny after changing to summer tire/wheels theman233 Issues | Warranty | Recalls / TSB 4 04-02-2017 01:48 AM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
First week off to a bad start, and a bunch on non-starts BCUZ BXR Issues | Warranty | Recalls / TSB 46 08-15-2013 07:04 PM
