Old 05-24-2022, 04:08 PM   #1
Kulebrero1
Drives: Gr86
Parts needed for rear camber adjustments
I’d like to upgrade the suspension on a 2022 GR86 for track duty primarily (HPDE and autox…not heavy duty completion or anything). I will still drive it on the street to/from track events plus the occasional trip to the mountains.
I’m thinking of going with the RaceComp Tarmac 2 coilovers paired with Verus Camber plates. I’m not familiar with the rear suspension on the 86. What would I need to be able to adjust the camber in the back?
I’ll be mounting 245/40/17 RS4s on 17x9 wheels.
Btw, do strut braces from the previous generation fit the 2022 models?
Kulebrero1 is offline   Reply With Quote
Old 05-24-2022, 04:34 PM   #2
Code Monkey
Drives: Subaru BRZ
My preferred way for camber in the rear is via upper control arms (RacerX, Cusco).
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Kulebrero1 (05-24-2022)
Old 05-24-2022, 05:10 PM   #3
Kulebrero1
Drives: Gr86
I just learned the Verus camber plates will not fit the 2022 GR86. Does anyone know for sure if the Vorshlag camber plates fit?
Old 05-24-2022, 05:11 PM   #4
Kulebrero1
Drives: Gr86
Will I need anything else? Down links?
Old 05-24-2022, 05:15 PM   #5
Code Monkey
Drives: Subaru BRZ
Coilovers will most likely come with adjustable endlinks. I also recommend the MCA traction mod.
Old 05-24-2022, 10:10 PM   #6
Kulebrero1
Drives: Gr86
Had not heard of the traction mod before. Does it actually help? And are they in Australia?
Old 05-25-2022, 03:04 AM   #7
Turdinator
Señor Member
Turdinator's Avatar
Its an Aussie company and certainly on Gen 1 they made a difference.
1974 TA22 Celica
2013 86 GT
Best shop for alignment and camber adjustments in Eugene, OR? MilkyWitness Northwest 0 03-20-2021 05:48 PM
*SOLD* SPL Rear Lower Control Arms FRS BRZ 86 LCA Parts Adjustable Camber hirollaz Brakes, Suspension, Chassis 0 10-02-2017 07:05 PM
School me on camber adjustments... tanner CANADA 34 01-14-2016 09:31 PM
DIY camber adjustments? canadaRS1.0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-28-2015 07:08 PM
rear camber adjuster bolts or lower control arms needed? Raven23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-31-2013 01:30 AM
