Old 05-06-2022, 03:46 PM   #1
O Haiii
Drives: Toyota Tercel
Engine Damage Pics Need Advice
Long story short, one of our daily drivers was run without any oil. Dealer sent over pictures, but I am not knowledgeable enough to know what they show. Please let me know what damages you see. Dealer says cylinder wall pictured shows scoring, and the timing of the engine was completely thrown off. Dealer is giving us two options: 1. Access the variable timing "pins". If it's broken, replace and set it straight, and go from there hoping that nothing else is broken and the scoring cylinder wall doesnt pose other problems. 2. Replace engine completely.
What would be the best course of action? Please advise. Thank for any help.
O Haiii is offline   Reply With Quote
Old 05-06-2022, 04:29 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
User ban is appropriate in this case. Reported.
Old 05-06-2022, 08:41 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
i'm not following
Old 05-06-2022, 09:02 PM   #4
Ultramaroon
not playing cards
i'm not following
Look at the date stamp on the bore scope display
Old 05-07-2022, 01:08 AM   #5
soundman98
soundman98's Avatar
Don't ever look through my Flickr account.
My borescope and thermal camera do the same thing. Damn battery hogs, I don't use them all the time, so I yank the batteries when not in use. I'm not made of AA's! And of course, it's a 20 minute process to reset the time/date. I usually only do it if there's a serious problem I need to document.
Like cylinder walls.
Same with my digital calipers
None of the OP's other posts read like spam...
Old 05-07-2022, 01:13 AM   #6
soundman98
soundman98's Avatar
How many miles are on the motor?
Motors don't just jump timing for fun, I suspect it's a deeper problem. But I would also reset timing and hope for the best because if it's already FUBARed, a little extra effort for the cheap rout isn't going to make it any more dead.
Old 05-07-2022, 01:52 AM   #7
Ultramaroon
not playing cards
I disagree but I'm ready to be wrong.
edit: Ok, I'm wrong. I apologize, O Haiii. Went back to read more of the earlier threads. I say fix timing and do a compression test to rule out bent valves. If it checks good, run it. If it doesn't start knocking with a bad rod bearing, you got lucky.
Old 05-07-2022, 02:03 AM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Don't think it's a boxer.
Some more details like ID numbers from the block, make and model would help to research similar engine failure modes.
Old 05-09-2022, 11:43 AM   #9
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I'm not an mechanical expert (but also a novice) but how could running on low/no oil cause timing to jump?
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 05-09-2022, 12:42 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Hydraulic tensioner possibly
Old 05-09-2022, 12:48 PM   #11
Ultramaroon
not playing cards
I was thinking the same but they all have ratchets. Maybe slipped with vibration. Already loose because high mileage/worn guides?
Old 05-09-2022, 01:15 PM   #12
KillerBMotorsport
KillerBMotorsport's Avatar
How many miles are on this engine?
I would expect bearing failure long before bore scoring on these engines.
As far as the timing chain jumping a tooth, you have no way of knowing that from the pics here. In theory a worn chain, guides and tensioner could do it, but you'd need a bazillion miles. The timing mark you're showing is the factory timing indicator for ignition. It's used at the factory, but otherwise is next to useless, you don't 'change' timing on these cars like you did back in the day with a distributor. These cars are modern and have a crank position sensor that feeds the ECU so it can determine optimal spart timing. There are also Cam position sensors. If any of these sensors detect something not as it should be, you throw a CEL.
Did you have an active Check Engine Light on the dash?
KillerBMotorsport is offline   Reply With Quote
Old 05-09-2022, 04:38 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I was thinking that too but only thing that came to mind.
Old 05-09-2022, 04:42 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Did I damage or hurt my engine ? tonychet2 Engine, Exhaust, Transmission 32 03-11-2015 07:35 PM
Need advice on minor damage to FR-S trim babydriver Scion FR-S / Toyota 86 GT86 General Forum 14 10-30-2014 05:17 PM
Someone backed in to me (damage and repair pics inside) JBrochacho Scion FR-S / Toyota 86 GT86 General Forum 20 04-16-2014 04:11 AM
Slight body damage, bottom side below passenger door. Need advice! FR-S Matt Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 01-23-2014 08:40 PM
Advice on fender damage wbsrazzle Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 43 12-22-2013 07:03 PM
