Old 05-02-2022, 11:21 AM   #1
ffsrhys
Drives: 2012 GT86
Question White smoke from engine bay
Hi all, after some spirited running the day before I took my 86 out today and without using high revs a fairly noticable smoke smell started entering the cabin, I checked the engine bay after and quite a lot of white smoke was coming from the bottom of the engine bay.
Here is a video of the issue
Any ideas?
ffsrhys is offline   Reply With Quote
The Following User Says Thank You to ffsrhys For This Useful Post:
theneptune86 (05-02-2022)
Old 05-02-2022, 09:43 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
What did it smell like? Hard to tell if it's steam from a coolant leak of smoke from an oil leak. Either way, you will need to pull the bottom cover off and have a look.
Old 05-03-2022, 07:24 AM   #3
ffsrhys
Drives: 2012 GT86
quite a strong burning smell
Old 05-03-2022, 07:46 AM   #4
Trollhart
Trollhart's Avatar
Drives: 2013 Subaru BRZ Sport
Also check under the car, you might have collected a plastic bag somewhere on the road, now touching some hot part of the engine bay.
I have already seen this happen twice, once on my own BRZ. White smoke and burning smell.
Or it's a leak indeed. Coolant usually smells slightly sweet. Oil does not.
Trollhart is offline   Reply With Quote
Old 05-03-2022, 08:10 AM   #5
Is that oil I see running down the block in the left side of the shot?
Old 05-03-2022, 08:44 AM   #6
ffsrhys
Drives: 2012 GT86
I'll have a look underneath later today for debris/leak!
Old 10-25-2022, 02:09 PM   #7
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
I am detecting a faint burning oil smell when I sit idle in my car.
What's the update on this?
Falkon240 is offline   Reply With Quote
Old 10-26-2022, 10:28 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
oil is supposed to be inside the motor, not outside.
did you hit something? run over something? change something? let someone look at something?
the possibilities are nearly endless.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Tcoat (10-27-2022), x808drifter (10-27-2022)
Old 10-26-2022, 10:48 PM   #9
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
I just found my cam plate has started leaking, you might wanna check that.
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
wbradley (10-27-2022)
Old 10-26-2022, 11:40 PM   #10
soundman98
soundman98's Avatar
do you know a guy with a van?
Ultramaroon (10-27-2022), x808drifter (10-27-2022)
Old 10-27-2022, 01:29 AM   #11
Took me a sec, fool!
soundman98 (10-28-2022)
Old 10-27-2022, 01:35 PM   #12
wbradley
Sarcastic SOB
wbradley's Avatar
I prefer the Starsky and Hutch Gran Torino.
That looks almost like The A Team's van.
Old 10-27-2022, 01:49 PM   #13
soundman98 (10-28-2022), wbradley (10-27-2022)
Old 10-27-2022, 01:55 PM   #14
le sigh
engine issue, problem, smoke, white smoke
Video. White smoke in engine bay. Car sat for a few weeks. daniloneil8 Engine, Exhaust, Transmission 8 09-09-2024 07:41 PM
white smoke gt7877 Software Tuning 6 01-11-2020 08:26 AM
White smoke decelerating azynneo Engine, Exhaust, Transmission 6 07-23-2016 11:14 AM
White smoke from engine bay after hard driving mfbmike Issues | Warranty | Recalls / TSB 26 07-09-2014 03:45 AM
White smoke in Engine bay Pinoywhiz Engine, Exhaust, Transmission 7 04-07-2014 07:10 PM
