Old 05-30-2021, 01:41 PM   #1
TheRealBFKR
Drives: '18 WRB BRZ Limited w/ PP
Are these track coolant temps acceptable?
Hi all,
Got a JR Dual Rad/OC put in. In a fairly hot day (70F and very sunny) the cooler did its job and kept the oil at around 230F the whole time on a stock power 2018. I noticed that the coolant was hanging out around 210. I don't have the data logged, but I think it might have had some peaks at 220.
Is this within acceptable range? I assume the coolant temp is higher than when the car was stock without an OC because I am now putting more heat into the system from the oil.
Fans are working fine and I tried pretty hard to salvage the stock rad air blocking foams as much as I could (but it's not perfect)
TheRealBFKR is offline   Reply With Quote
Old 05-30-2021, 02:35 PM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I think it`s acceptable. Slightly higher water temp than i would have thought from the system, But as you said
In similar ambient temp I`m seeing 195 water and 222 oil. Stock rad and a dual pass oil filter
gen3v8 is offline   Reply With Quote
Old 05-31-2021, 06:06 PM   #3
210/230? Totally acceptable.
Add hood vents for even more cooling, and you can also blast your heater (AC off) as well.
norcalpb (06-01-2021), Wally86 (06-03-2021)
Coolant temps with Jackson radiator? dstrout Engine, Exhaust, Transmission 1 07-11-2018 03:26 PM
FLKC in high gears (e.g track). What is acceptable? Tor Software Tuning 61 11-02-2017 08:24 AM
Coolant Temps Running High Dezoris Tracking / Autocross / HPDE / Drifting 43 09-29-2016 11:58 AM
Coolant Temps WAY TOO HIGH itsjustdavep Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 45 08-25-2016 01:41 PM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
