Old 04-13-2022, 01:00 AM   #1
gpvecchi
gpvecchi's Avatar
Squeaky power window
My left power window makes an annoying squeaking sound, does anybody experience the same issue?
gpvecchi is offline   Reply With Quote
Old 04-13-2022, 04:07 AM   #2
QHawk
QHawk's Avatar
Drives: 2020 86GT
Yes. Same with my 2020, traveling down only, and the squeal is piercing. In my 86 the culprit is the gasket that the glass travels between as it moves. I've experimented with stretching the gasket slightly by pulling a small dowel along it (both sides with the window down) to stretch it away from the glass, but the effect was minor and temporary. I've tried waxing the gasket by using a slim candle in the same way. That worked better but, again, only temporarily. A good solution would be welcome.
QHawk is offline   Reply With Quote
The Following User Says Thank You to QHawk For This Useful Post:
gpvecchi (04-14-2022)
Old 04-13-2022, 08:54 AM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
If the noise is from the glass sliding on the gasket, try silicone spray.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 04-13-2022, 03:59 PM   #4
gpvecchi
gpvecchi's Avatar
Thanks, do you mean the gasket inside the door, in the vertical guides for the glass, right?
I heard of other 86 with the same issue, only driver glass, and only going down.
Old 04-13-2022, 08:26 PM   #5
QHawk
QHawk's Avatar
Drives: 2020 86GT
...the gasket inside the door, in the vertical guides for the glass, right?
Yes. I can't be sure if the inner or outer side is causing the squeal.
Old 04-13-2022, 10:44 PM   #6
whataboutbob
AutoX-10/10ths every run
Clean the inside and outside window gasket surfaces as completely as you can. Then spray the inside and outside of the window completely with rain-x. Be sure to wipe it down after the rain-x dries.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
gpvecchi (04-14-2022), QHawk (04-28-2022)
Old 04-15-2022, 04:40 PM   #7
QHawk
QHawk's Avatar
Drives: 2020 86GT
Rain-X is worth trying. I'll get some this weekend. Thanks.
gpvecchi (04-16-2022)
Old 04-28-2022, 08:14 PM   #8
QHawk
QHawk's Avatar
Drives: 2020 86GT
Rain-X has made a difference. I've used it only on the inside of the window to isolate which side has been squealing, and no squealing so far.
Good suggestion. Thanks.
whataboutbob (04-28-2022)
Old 04-28-2022, 09:35 PM   #9
whataboutbob
You're welcome.
Build thread:Here
Schematic for power window switch? TeeJayHoward Electronics | Audio | NAV | Infotainment 1 04-23-2020 11:23 PM
Power window help FenixFury Electronics | Audio | NAV | Infotainment 22 01-20-2018 08:51 PM
Power window broke itself.. Ddreder Issues | Warranty | Recalls / TSB 20 11-25-2014 03:56 AM
Power window fault in cold weather Suberman Issues | Warranty | Recalls / TSB 5 01-09-2014 09:24 AM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 05:34 AM
