Old 11-13-2017, 10:48 AM   #1
FenixFury
Drives: 2013 black Scion FRS
Power window help
Hello everyone!
For starters, I drive a 2013 FRS, second owner.
I had an issue where the passenger window would roll down, but wouldn't come back up, with the indicator light on the switch blinking every time I tried to work the window.
I took it to the mechanic to see what's up, and have the window set so I can open and close the door at least until I get new parts (if needed.) He said I need a new switch on the door because it crapped out due to the previous owner being a smoker and all that. So I said okay, I'll get one from work, as I work at a car parts store.
Now that I'm at work and reading on the forums, I'm seeing that I might just have to reset the programming on the windows by doing the button holding bit, because the light is still blinking, ergo the switch still might work.
I'm afraid that if I try this and it doesn't work, the window won't roll back up, and I'm screwed until I can get a new part and go to the mechanic again.
I live in Canada and it's like 5 celsius or less, and supposed to be wet this week.
Thoughts?
Sent from my G3223 using Tapatalk
FenixFury is offline   Reply With Quote
Old 11-13-2017, 02:48 PM   #2
Originally Posted by FenixFury View Post
Hello everyone!
Thoughts?
Do the reset it will work fine.
Not sure how being a smoker ruins a switch.
Old 11-13-2017, 02:50 PM   #3
FenixFury
Idk, something about rolling the window down and getting moisture in there? It didn't really make much sense to me either honestly.
I'll give it a shot when I get home, just in case it decides to shit the bed.
The Following User Says Thank You to FenixFury For This Useful Post:
Tcoat (11-13-2017)
Old 11-13-2017, 11:41 PM   #4
CraigVM
Drives: Car Collector
perhaps
Perhaps lack of ash tray and cold temps outside had the chain smoking passanger rolling down the window constantly to flick ashes off and rolling them back to keep warm ???
CraigVM is offline   Reply With Quote
Old 11-14-2017, 12:15 AM   #5
FenixFury
He smoked weed, not cigarettes lol but maybe?
Old 11-14-2017, 01:11 AM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
The only one smoking was your mechanic, and he was blowing it up your ass. There are two switches for the passenger door. If the window behaves the same way for both, then there's nothing wrong with either.
I'm with Tcoat. Zero out the limits before assuming anything's actually wrong.
Tcoat (11-14-2017)
Old 11-14-2017, 01:13 AM   #7
FenixFury
Yeah, I figured since it was doing it on both switches, and they were both still lit up and blinking, then they're not broken and the circuit isn't interrupted like he said.
Old 11-14-2017, 12:31 PM   #8
Try the reset yet?
Old 11-14-2017, 08:16 PM   #9
FenixFury
Try the reset yet?
Haven't done it yet; my natural womanly paranoia makes me afraid the window won't roll up when I start the reset. (Because the original problem is that it won't roll up.)
I read somewhere that if you do it on the driver's side window, it resets both windows, which doesn't really make much sense...
Just to make sure, you put the car with power to accessories but not engine, roll down til you hear a click, then roll back up til you hear a click, yeah?
Old 11-14-2017, 08:38 PM   #10
Nope that isn't how it is done.
You have to hold the buttons UP in the sequence below. You have nothing to fear in trying it.
Old 11-14-2017, 10:04 PM   #11
FenixFury
Tried to do the reset.
Fiddled with the button on the passenger door and it wasn't responding despite blinking. Tried the one on the driver door that corresponds to the passenger window and it didn't do anything either. Tried the reset sequence and it didn't do anything.
Not sure if the mechanic didn't reconnect it properly, or if something is actually fucked.
Old 11-14-2017, 10:52 PM   #12
TOLM
Drives: Brz
Now you are blaming the mechanic lol ))
TOLM is offline   Reply With Quote
Old 11-14-2017, 11:09 PM   #13
FenixFury
Well, I did the sequence exactly as it said so...?
Old 11-15-2017, 12:16 AM   #14
Ultramaroon
not playing cards
Does it go up some and then stop? If so, does it do it the same way every time?
Does it sound/feel like a jam, or does it seem electrical, like it just dies?
Passenger side power window circuit Fastbrew Electronics | Audio | NAV | Infotainment 3 11-22-2015 11:10 PM
Power window broke itself.. Ddreder Issues | Warranty | Recalls / TSB 20 11-25-2014 04:56 AM
Power window fault in cold weather Suberman Issues | Warranty | Recalls / TSB 5 01-09-2014 10:24 AM
Power window auto drop fault ? Suberman CANADA 2 11-09-2013 08:14 PM
FRS/BRZ BRUSHED SATIN POWER WINDOW SWITCH TRIM zetaproducts.net Interior Parts (Incl. Lighting) 28 05-14-2013 10:32 AM
