Old 04-11-2022, 11:52 PM   #1
dynarun55
Drives: 2015 midnight blue limited edition.
Clutch rating
So I did quite a bit searching for a torque rating of the stock clutch.. I came across numbers ranging from 235 ft-lb wheel torque ( dont know which dyno) 90 ft-lb wheel torque.
The stage 1 Exedy clutch which is allegedly produced on the same line as the stock clutch has a rating of 166 ft-lb wheel torque (again dont know which dyno) but also mention that the components should hold 40% more load than the stock. To throw in another variable, you have Jackson racing supercharger website claiming they have run thousands of their CARB legal tune (makes 45% more torque on the stock clutch ) without any problems. Thoughts...?
Sent from my Pixel 3 using Tapatalk
dynarun55 is offline   Reply With Quote
Old 04-12-2022, 02:54 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Stock clutch is rated to slip before munching the transmission outright. Keep it. JR is correct.
Old 04-12-2022, 09:25 AM   #3
dynarun55
Yeah I'm sure JR is correct.. Just curious on the actual numbers on the stock clutch, assuming that it would have been designed to protect the tranny from an NA engine..
Old 04-12-2022, 08:33 PM   #4
There aren't any.
ZF clutch in Toyota TS050 - 1.85kg, 115mm friction disc, 1600NM torque rating. mav1178 Other Vehicles & General Automotive Discussions 7 06-29-2016 11:33 AM
MPG (KM/L) Rating Mikeez Scion FR-S / Toyota 86 GT86 General Forum 39 12-17-2014 03:27 PM
FX400 Clutchmasters Clutch & Flywheel kit...500TQ Rating w/ Less than 1k miles deedz Transmission and Driveline 0 11-15-2014 12:23 AM
EPA rating for 918 Spyder: 20/24 serialk11r Other Vehicles & General Automotive Discussions 9 04-22-2014 07:36 PM
Trader Rating? 86_ZN6 Site Announcements / Questions / Issues 5 06-30-2012 06:43 PM
