Metallic squeal/scrape sound after doing wheel studs
So I worked over the winter to replace the wheel studs as the PO had someone go ham on them with an impact gun. Taking them out was simple enough after I recognized the leverage necessary to get the caliper brackets off the front. Did the fronts, test drove and all was well. Finished up the rears a couple weeks ago and now all of a sudden I have a horrible metallic squeal/scraping sound coming from the rear.
Finally had time to take it apart tonight and seemed like the pads were sitting on the rotors so I flexed them a bit to the point where they were spread a bit, buttoned it all up and before I even left the garage, same awful noise. Ideas of what I fucked up? Car is a '17 PP car that wasn't driven all winter, only has 21k on it and likely the original pads and rotors though both have plenty of meat left. Also car wasn't making this or any other nosie prior to me taking on this little project. Thanks in advance. |
Quick check now and I can see both rear pads sitting on the rotors, car is off, etc. Other observation I made was I couldn't recall seeing this bracket on the driver's rear before and seemed odd it wasn't connected to anything on one end, but seems it's just there to keep the brake line away from the wheel maybe?
Also what do I need to do to get the pads to sit back off the rotors again? |
Realize this is probably basic shit for someone who knows what they're doing....I'm just not that person (yet anyway). Appreciate any help getting this fixed so I don't have to take it to a shop.
| The Following User Says Thank You to ThatYeti For This Useful Post: | Ultramaroon (04-12-2022) |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
Have you pulled the brake rotor in the rear to check the parking brake?
Is the rear dust shield rubbing against the rotor after being pried on possibly? Possibly a piece of metal or some crud got stuck in the parking brake drum? |
| The Following 2 Users Say Thank You to murdoc For This Useful Post: | ThatYeti (04-12-2022), whataboutbob (04-11-2022) |
AutoX-10/10ths every run
"Finished up the rears a couple weeks ago and now all of a sudden I have a horrible metallic squeal/scraping sound coming from the rear."
Does this mean that initially you drove the car after doing the rears and had no sounds, but now there are sounds?
Sorry to clarify I drove it after the fronts were done and all was OK. Drove it after doing the rears and started hearing the noise.
| The Following User Says Thank You to ThatYeti For This Useful Post: | whataboutbob (04-12-2022) |
I'd taken the rotors off to get the studs out but don't recall prying on the dust shields at all and the only spot where I saw any kind of rubbing was on the edge of that bracket I posted, on the side facing towards in middle of the car, so while I still don't really understand what it's for I don't think it's the issue.
not playing cards
That bracket just keeps the brake cable safe. I think you accidentally bent one of the dust shields. It's easy to do without even realizing it. Get underneath it and spin each of the rear wheels by hand. I bet you'll immediately find the source.
Also, the pads are supposed to touch the rotor. To prove it to yourself, separate a pair like you did but this time, notice that your brake pedal sinks to the floor the first time you press it.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | ThatYeti (04-12-2022) |
#9 | |
#10 |
Take everything in the rears back apart and inspect. Inspect parking brake good. Also adjust parking brake when you put the rotors back on.
#11 |
Never touched anything with the parking brake and didn't touch the fluid system either so didn't think I needed to do anything with that. Can you explain what I need to do when you say 'adjust the parking brake'?
#12 | |
not playing cards
Look in my sig line for the manuals. Drill down for parking brake system adjustment. Also to Grady's point. Maybe a spring came loose or something didn't go together properly. Hell, I had made plenty of dumb mistakes before learning how to study all the moving parts before disassembling them. Look here for the parking brake cable support bracket. It should be tightly clamped to the trailing arm ...ok " no. 1 suspension arm assembly"
| High pitched squeal only when braking only with a winter wheel | PatMegron | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 12-16-2020 04:57 PM |
| Squeal/whine when steering wheel is turning | motomike | Issues | Warranty | Recalls / TSB | 4 | 10-08-2019 07:31 AM |
| Brief Scratching/squeal sound. Accelerating/change gears. | resli | Issues | Warranty | Recalls / TSB | 13 | 03-02-2016 01:56 AM |
| metallic sound coming from engine when accelerating! | jaorocks1 | Issues | Warranty | Recalls / TSB | 4 | 05-02-2015 11:32 PM |
| Metallic Rattling sound past 4k | J-Money | Issues | Warranty | Recalls / TSB | 2 | 05-05-2014 10:59 AM |
