Old 09-01-2019, 07:46 AM   #1
motomike
Drives: 2013 Subaru BRZ Sport Tech
Squeal/whine when steering wheel is turning
Hi all,
I’ve had an issue with my BRZ for a while now and I want to find a solution for it. Occasionally you can hear a squeal/whine when turning. This will happen both at low speeds (when reversing in a parking lot) and on the highway. It sounds like the power steering is low on fluid, but from my understanding this car has electric power steering so I’m not sure what it could be.
I attached a video to show the issue. Any help with diagnosing the issue would be greatly appreciated.
motomike is offline   Reply With Quote
Old 09-01-2019, 08:19 AM   #2
ermax
ermax's Avatar
EPS unit. New they are about 1400 but you can get them used cheap. If you get one used I would replace the coupler before installing it.
Old 09-01-2019, 08:29 AM   #3
gravitylover
Mine was more of a groan but similar enough I think. Subaru replaced the steering column, steering wheel and EPS unit. It took them several tries over the course of a month before it finally went away but they eventually got it after the column and wheel replacement. They actually blamed me because I'm short and the seat is pretty far forward, they said I was pushing against the wheel too hard getting in and I bent the wheel and upper column. Whatever... It has been about 45k miles since and hasn't come back.
Old 09-03-2019, 05:12 PM   #4
motomike
Thanks guys!
I’ll take a good look at my steering wheel, but I don’t think that’s the problem. I think I might try to replace the EPS if I can find one locally. Hopefully that will solve it.
I’ll update when I do.
Old 10-08-2019, 06:31 AM   #5
motomike
Finally figured out the problem. The brake pads were done and somehow a price of rust got stuck On the drivers side between the rotor and the calliper. Hope this helps someone in the future.
Clunk noise when turning steering wheel to right noonedoesnt Issues | Warranty | Recalls / TSB 15 07-03-2018 09:14 PM
Creaking from front end when turning steering wheel finch1750 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-05-2015 03:21 AM
Noise when turning steering wheel at low speed Slant Issues | Warranty | Recalls / TSB 7 11-06-2015 08:53 AM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
Heavy steering when turning left... Venator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-10-2015 03:07 PM
