Old 04-05-2022, 10:45 PM   #1
brzperson
How to know if "tone wheel"/reluctor wheel is oriented correctly?
I really think that there should be a sticky in the forum regarding this wheel.
To be more specific, I am referring to the wheel in this post.
https://www.ft86club.com/forums/show...=119729&page=3
I have seen videos and forum topics of people who have gotten the orientation of that wheel wrong, and its something that isnt common on many engines (meaning even experienced people can miss it), can easily bolt back up without any sign of weirdness, and is something that can easily fall off when taking off the flywheel.
In any case, i have heard that checking your rpm readings from scanner to tach, is a good way to determine if you put it in correctly, assuming your car starts and doesnt have weid timing issues.
I know that there is an engine peephole, but that is likely to only tell you if the teeth are facing the correct direction.
Does anyone know of a good way to check if its on correctly without pulling the trans and looking at it?
Thanks!
brzperson is offline   Reply With Quote
Old 12-08-2023, 10:25 AM   #2
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
The reluctor wheel has a line up hole that aligns with a pin on the crank. It won't sit flush if it's not lined up correctly.
Sent from my SM-S908U using Tapatalk
jbailey8748 is offline   Reply With Quote
BRAND NEW Vertex "King" 330mm Steering Wheel Black TeamJacobs111711 Interior Parts (Incl. Lighting) 0 10-06-2017 10:54 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 02-25-2014 06:00 AM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 JDMenrique Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 08-25-2013 01:48 PM
"Performance" Oriented Intake system?? eddieEndo Engine, Exhaust, Transmission 25 07-07-2013 11:02 AM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x7.5 +47 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-31-2012 04:17 PM
