Old 04-01-2022, 09:35 PM   #1
Nintain
Drives: 2015 Scion FR-S A/T
Camshaft question
I'm currently rebuilding my engine after a rocker arm slipped out destroying my engine. The cylinder head that got damaged was the passenger side absolutely not reusable even the cams. I had bought a cylinder head used about a year ago and the person that was supposed to dothe engine work for me was unreliable to checking the part and ended up being the wrong side. The vendor is in the right to not help give me a refund or at least give me the correct side that I had actually ordered.
Anyways, to save money I was planning on using the cams in the used passenger side cylinder head to replace the new driver side cylinder head that I'm planning to construct. My question is that, are the sizes for the cams on the drivers side the same for the passenger so that I can use the cams?
Nintain is offline   Reply With Quote
Old 04-02-2022, 10:41 AM   #2
makinen
makinen's Avatar
Drives: Toyota 86
No.
Look at the high pressure fuel pump cam and the vacuum pump pin.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 04-02-2022, 01:33 PM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Be careful about mixing and matching parts. I've heard that there are some variations in the heads, rocker arms, and cams from year to year.
camshaft, engine, engine rebuild
Camshaft kinginfamous5 Engine, Exhaust, Transmission 4 07-27-2020 03:41 PM
Camshaft's Lunatic Engine, Exhaust, Transmission 8 04-06-2018 08:18 PM
Piper Camshaft.. Walla Walla Engine, Exhaust, Transmission 5 05-12-2017 08:46 AM
Camshaft Bearing FRSloth Engine, Exhaust, Transmission 1 10-15-2016 02:19 AM
Camshaft Teaser... Carolina Dyno Forced Induction 7 07-16-2015 06:38 PM
