Drives: 2015 Raven FRS
Camshaft's
Are 2012 cams the same grind as 2015 and can 2012 cams be installed in a 2015 engine?
Drives: '15 BRZ RA
They are different. The parts were changed to accommodate the changed lengths of the valves. Check below:
Camshaft, Intake, RH old SU003-00180 new SU003-04741 Camshaft, Exhaust, RH old SU003-00181 new SU003-04742 The change was done in May 2013. In general 2014-2016 models have the same valves, only 2013 has the earlier valves. |
#3 | |
Drives: '15 BRZ RA
#5 | |
Drives: 2013 FR-S, 2016 Miata Club
So how do I know which ones I have?
Drives: '15 BRZ RA
These are the Subaru part numbers for the '15 model car:
![]() It looks that yours are the first version. |
Found a set of 2014's. Thank you all.
| Piper Camshaft.. | Walla Walla | Engine, Exhaust, Transmission | 5 | 05-12-2017 08:46 AM |
| Camshaft Bearing | FRSloth | Engine, Exhaust, Transmission | 1 | 10-15-2016 02:19 AM |
| camshaft CLEARANCE | aagun | Engine, Exhaust, Transmission | 22 | 10-03-2015 09:24 PM |
| camshaft CLEARANCE | aagun | Software Tuning | 1 | 09-05-2015 07:49 AM |
| New TSB for camshaft sensor | whitefrs | Issues | Warranty | Recalls / TSB | 13 | 03-11-2014 02:54 PM |
