Old 07-26-2020, 11:22 PM   #1
kinginfamous5
Drives: 2013 Scion FRS
Camshaft
Hey everyone, 2013 FRS Im ready to throw this car away. I started to get the coil pack issues, specifically with coil number 3. The Subaru Service Bulletin said to replace the wiring harness and coil packs to 2015 harness. I read a lot of people had great results with just repining the harness with 2015 connectors, I went that route. Took off the harness and repined the 4 coil connectors. Reinstalled everything and the car idled great. I let it idle for about 30 minutes to make sure it was fine before I drive it. Well after 30 minutes CEL came on. Scanned it and now P0390 & P0391 comes up, cleared it to see if it was a fluke and popped up immediately. Swapped sensors to see if the problem moved but no, stayed in the same bank and sensor. So I spliced in about a foot of new wires and a new connector. Still the same thing.
Any ideas?
kinginfamous5 is offline   Reply With Quote
Old 07-27-2020, 03:09 PM   #2
humfrz
Bad spark plug? -
Old 07-27-2020, 03:33 PM   #3
kinginfamous5
Bad spark plug? -
Thanks for your reply. Spark plugs are a month old.
Old 07-27-2020, 03:39 PM   #4
humfrz
I can't tell from your reply, did you get new (or at least switch coil packs)?
Old 07-27-2020, 03:41 PM   #5
kinginfamous5
The coil pack issues are gone now. Now its the P0390 and P0391 Camshaft sensor.
camshaft, camshaft sensor, cel, p03
Scored camshaft dengee Issues | Warranty | Recalls / TSB 17 05-04-2019 07:56 PM
Camshaft's Lunatic Engine, Exhaust, Transmission 8 04-06-2018 08:18 PM
Piper Camshaft.. Walla Walla Engine, Exhaust, Transmission 5 05-12-2017 08:46 AM
Camshaft Bearing FRSloth Engine, Exhaust, Transmission 1 10-15-2016 02:19 AM
camshaft CLEARANCE aagun Software Tuning 1 09-05-2015 07:49 AM
