Header Question
Anyone gone from a r400 to a q300, then got a uel? I had an r400 swapped to a q300 due to the drone at highway speeds and on hills.
q300 is fine by itself but want to add a psr uel & overpipe and leave front pipe stock. From what I've read drone shouldn't be an issue with this setup, any feedback appreciated. thanks! |
I think it should be fine, but what others have noted is that the q300 muffler packing can disintegrate over time leaving you with a loud exhaust setup.
Professional wrench
Drives: 2020 BRZ ST RS
I recently put in a header and overpipe, with STOCK exhaust from there back. its louder than stock by a good amount. I might try that if I were you. Before you try anything with more volume, at least
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
Drives: BMW E30, 2014 FR-S
I had the UEL headers, then the R400 exhaust, then the Q300 exhaust and then added a catless resonated frontpipe. The last thing I did was use two STI hangers for the rear two hangers. There's no drone when cruising on the highway - mostly just the typical tire noise and NVH. It's almost stock level. When you floor it, it gets loud.
| Header Question | frickenchick | Engine, Exhaust, Transmission | 4 | 09-11-2021 09:16 PM |
| JDL Header Question | Swolzee | Engine, Exhaust, Transmission | 5 | 05-20-2021 01:17 AM |
| Header on N/A question | FR-Shred | Engine, Exhaust, Transmission | 4 | 06-19-2015 07:47 AM |
| UEL Header question | iarefluffy | Engine, Exhaust, Transmission | 12 | 01-26-2015 12:16 AM |
| Header question | ft86me | Engine, Exhaust, Transmission | 18 | 03-14-2013 12:38 AM |
