Old 06-19-2015, 05:56 AM   #1
FR-Shred
FR-Shred's Avatar
Header on N/A question
Set up:
Borla UEL (just installed two days ago)
Invidia N1 Ti Exhaust
Invidia Resonated Front Pipe
Tanabe Overpipe
Greddy Intake.
So.. I am maybe thinking there's a exhaust leak somewhere due to the sound while under acceleration and WOT.
I know with no more shielding and no cats its going to sound a lot different but to me it sounds like I am running a dump pipe or open headers when I give it a bit of throttle.
When I am idle or cruising, it sounds about the same as pre uel header, more throaty but you still hear the exhaust sound. But when I give it throttle you dont even get an exhaust note anymore, like I said to me its like open dump/header. I am going to have someone else drive it by me or record it from the outside while I drive by, cause maybe just inside the cabin is giving me a different sound.
Anyways, anyone else have the same or similar set up and can comment (or have a video) on the sound and/or the overall sound at throttle that would be nice.
I am probably going to re-tighten all the bolts and do a paper test on the gasket areas today to check..
I was thinking about taking it to an exhaust shop and having them give it a once over, but if I could not have to do that by re-tightening and/or getting some feedback on here that would be great.
The reason I am not thinking leak is because I would imagine it would have to be a HUGE leak, like a missing pipe (haha) to be giving off this much sound, or will a small leak do this also?
Thanks.
FR-Shred is offline   Reply With Quote
Old 06-19-2015, 06:18 AM   #2
steve99
Originally Posted by FR-Shred View Post
Set up:
Tanabe Overpipe
Greddy Intake.
Thanks.
Catless header and invida n1 is going to be very loud especially with what i assume is a catless but resonated front pipe.
I think you will need to change catback to stock or Q300 to get the sound levels acceptable.
you might have asmall leakas well but they just usually throw off fuel trimsand may make car run crap or hesitations\bogging.
your gready intake will likey require maf rescale, assume you are running tune.
log your long term fuel trims at low rpm will usually give you indication of leak
Old 06-19-2015, 06:32 AM   #3
FR-Shred
FR-Shred's Avatar
Catless header catless front pipe.
I do not mind the sound level itself, I just would like a more pronounced exhaust sound. A deep loud rumble is what I am looking for and as of right now its just an open dump sound, no real noticeable rumble or exhaust note at all, while giving it a bit of throttle.
I am not getting any hesitations or bogging that I have noticed as of yet. If they are pretty noticeable I would say I dont have any, if they are very minor I will pay more attention on my drive home from work.
I am currently not running a tune. That is my next step. I did not want to have to spend $$ on tunes when I would upgrade to new items, going stage 1 to 2 for example. I am done with all the mods that would require a different tune until I get a turbo, so now I am 1-2 months away from going flex fuel and tune.
I have not noticed any negative effects on my drives with the intake. BUT I did by the car used with the intake on so possibly the original owner had a tune on it. I have also read that a lot of people do not have any negative effects running a intake without a tune, so I might be one of those cases.
Old 06-19-2015, 06:42 AM   #4
steve99
Some intakes dont throw of maf scaling much like mishimoto,Grimmspeed, perrin 2.5 " , others like takeda and injen do, not sure in Gready but from your experience its probably ok.
An invidia n1 with stock catted header and stock catted midpipe is loud but the cats cut down on a lot of noise rasp ect, going catless header andd midpipe with an N1 it going to be pretty loud and raw and not a refined throaty note.
Its going to be difficult to fix without changing the catback to something with a proper muffler and a quiet one like a q300 rarther than a canister type.
your likely to throw a P0420 cel code soon with catless heaer and no tune
Old 06-19-2015, 06:47 AM   #5
FR-Shred
FR-Shred's Avatar
The Greddy is a rebadged takeda so possibly. I have just not noticed any ill effects.
So from your input I am just assuming its the sound it is, loud and raw are accurate. It sounds like a muscle car, meanest 200hp car I have ever heard, hahah.
I, to be honest, want a louder exhaust. Not cause its louder but cause its lighter and I personally want a single exit.
And I am aware about the CEL code, I can live with that for a month or so, it isn't a big deal. I have a bluetooth OBD reader so I can make sure its not other codes in the meantime, but it has yet to come on. I have heard it taking up to 500+ miles sometimes.
Thanks for the help.
UEL Header question iarefluffy Engine, Exhaust, Transmission 12 01-25-2015 11:16 PM
Header Question exam2300 Engine, Exhaust, Transmission 6 08-13-2014 07:03 PM
Header/non res catback question Pryz228 Engine, Exhaust, Transmission 0 08-09-2014 12:40 PM
Header question ft86me Engine, Exhaust, Transmission 18 03-13-2013 11:38 PM
Stock Header Question wootwoot Engine, Exhaust, Transmission 12 12-24-2012 05:24 PM
