Old 03-16-2022, 01:27 PM   #1
Jstyle
Jstyle's Avatar
Drives: 2020 86
Towing the track car
I just picked up a trailer to tow my 86 down to VIR (about a 4 hour drive) and I have a question since I’ve never towed with a trailer that has a dovetail.
My question is, should I have my 86 centered over the trailer axles OR should I have it forward just enough to have the back tires past the slope of the dovetail?
Thanks!
Jstyle is offline   Reply With Quote
Old 03-16-2022, 01:37 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The car should be positioned so you have the appropriate tongue weight on the tow vehicle.
The Following 10 Users Say Thank You to NoHaveMSG For This Useful Post:
Icecreamtruk (03-17-2022), ka-t_240 (03-17-2022), Kelse92 (03-16-2022), M0nk3y (03-18-2022), Opie (03-31-2022), RedReplicant (03-16-2022), Shark_Bait88 (03-17-2022), soundman98 (03-17-2022), thomasmryan (03-17-2022), villainous_frx (03-16-2022)
Old 03-16-2022, 02:09 PM   #3
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Forward. The farther back the weight is the more chance for fishtailing if you have to to make a sudden move
Old 03-16-2022, 03:00 PM   #4
redlined600
redlined600's Avatar
Drives: Fr-s
This is truly the correct answer, however, I have found that the car centered over the front trailer axle gives enough tongue weight for a stable pull. YMMV
The Following 2 Users Say Thank You to redlined600 For This Useful Post:
NoHaveMSG (03-16-2022), soundman98 (03-17-2022)
Old 03-16-2022, 03:47 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There's for sure some leeway. I run my car a bit forward as well and balance it out with my airbags. Too rearward is always bad.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
evanescent03 (04-20-2022)
Old 03-16-2022, 09:47 PM   #6
Jstyle
Jstyle's Avatar
Drives: 2020 86
So how do I tell what the “proper tongue weight” is?
Old 03-16-2022, 09:49 PM   #7
Eric1855
Drives: LP DSP / CSP '13 BRZ
you want to put the car where ~10% (up to 15%, but no higher) of the combined trailer weight is on the tongue. So figure that trailer there is say 1700lbs, the car as loaded is 2800lbs thats 4500 gross trailer weight.
So you'd want to set the car where you have 450-675lbs on the tongue. You can get a fancy tongue scale, or use a scale at a truck stop, or just use a little geometry some wood and a bathroom scale https://www.etrailer.com/faq-how-to-...ue-weight.aspx
Proper tongue weight helps to make sure you won't get a fishtailing trailer and also helps braking and handling of the tow vehicle, but the impact can be lessened by other factors to like a WD hitch, anti-sway hitch, anti-sway control in your truck, etc...
Eric1855 is offline   Reply With Quote
The Following User Says Thank You to Eric1855 For This Useful Post:
Old 03-17-2022, 08:11 AM   #8
Autoxer62
You'll end up with too much on the tongue using this calculation. With no load the trailer already has the 10% on the tongue, that's why you can tow the empty trailer unballasted. All you need to adjust for is the car, so 300 pounds is the target number.
Here's another way, assuming you have a 200 pound friend - hook up the trailer, and measure the hitch distance to the ground. Now have your friend step up onto the hitch and measure again. The difference is 200 pounds of tongue weight. Let's say it's 1". Load the car until the tongue drops 1 1/2" and you have 300 pounds on the tongue.
Adjust the multiplier as needed for the weight of your friend. If it's your wife, use the correct number for the measurement, but tell everyone it's "about 3"
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
The Following 2 Users Say Thank You to Autoxer62 For This Useful Post:
evanescent03 (04-20-2022), soundman98 (03-17-2022)
Old 03-17-2022, 09:45 AM   #9
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
The easy button to tongue weight is these - but they are a bit pricey
https://www.weigh-safe.com/
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 03-17-2022, 01:24 PM   #10
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Proper tongue weight, as others have described here well, is very important. You also might want to consider an anti-sway bar, especially if you'll be going long distances. I towed a 10,000-pound trailer behind a motorhome for several years, but had a revelation one day when following a truck towing a travel trailer. I watched the trailer swaying back and forth and pushing the rear of the truck from side to side as well. In the next town I had an anti-sway bar installed. I found I could run faster and stay behind the wheel an extra couple of hours a day, since the rig moved as a single unit instead of two pieces hinged in the middle and pushing each other side to side. I had avoided them because I understood it was difficult to back up with one but I found it was no problem at all. I think you can get them for something like $75 to $125 plus installation.
Qwimby1 is offline   Reply With Quote
The Following User Says Thank You to Qwimby1 For This Useful Post:
NoHaveMSG (03-17-2022)
Old 03-17-2022, 03:17 PM   #11
CedN
CedN's Avatar
Drives: 2013 GT86 fully standard
You guys seems to load the towing hitch alot over there. In general here the tow hitches are normally rated to around max 80kg (about 175lbs, some have up to 220 lbs ).
2013 GT86, fully standard daily and occasional track day car
CedN is offline   Reply With Quote
Old 03-17-2022, 05:43 PM   #12
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
if you will be using ratcheting type straps, be sure to have at least two turns/wraps around the spool mechanism.
friction is a thing.
thomasmryan is offline   Reply With Quote
The Following 2 Users Say Thank You to thomasmryan For This Useful Post:
evanescent03 (04-20-2022), Opie (03-31-2022)
Old 03-17-2022, 06:22 PM   #13
Eric1855
It definitely depends on what you’re towing with and the class of the hitch being used. The trailer tongue weight should be added into the GVWR of your vehicle to not exceed what’s safe so if you’re towing with a smaller SUV you may be limited on tow capacity and GVWR vs something like a HD truck (I have a RAM 2500) that can tow a stupid amount and a high GVWR that allows for more tongue weight and therefore more trailer.
Another thing not mentioned is trailer brake control. Trailers either have no brakes, surge brakes, or electronic brakes.
If electronic you’ll need a controller if your vehicle does not have one integrated, like a Tekonsha Prodigy, to ensure they work properly.
Old 03-17-2022, 08:47 PM   #14
Autoxer62
+1 on trailer sway bar and trailer brakes. Get the balance right and it's like driving a train. Oh, and you might upgrade the brake pads on the truck if you haven't already.
Towing your 86 ka-t_240 Tracking / Autocross / HPDE / Drifting 70 03-01-2024 07:52 PM
Towing with the FR-S tobkin Scion FR-S / Toyota 86 GT86 General Forum 36 08-21-2020 01:08 PM
Towing a FRS Lunatic Scion FR-S / Toyota 86 GT86 General Forum 7 07-24-2014 10:55 PM
Towing with the FR-S CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 23 07-18-2012 09:34 AM
