Old 03-12-2022, 08:15 PM   #1
bryanjuz94
Drives: 2014 Subaru BRZ
2014 Turbo BRZ - Built Motor PTE6266 - South Florida
I am selling my 2014 Subaru BRZ due to me wanting to purchase a ZL1 1LE. Motor was built by IAG Motorsports. Makes 681rwhp on E85 it is still on old tune from previous setup. The current setup is capable of making 700HP+. The vehicle is located in South Florida.
Mileage: 39,936
Clean title
Now: 25k
The Modifications:
- IAG closed deck long block
- IAG Spec 86.25 MM Forged Pistons
- Manley FA20 HD wrist pins
- King XPG Rod bearings
- King XPG main bearing set
- heads have complete ferrea valve train
- GSC Power-Division valve seals
- Closed deck and O-ringed block14MM headstuds
- Manley I-Beam connecting rods
- New timing chain was done along with tensioners, and guides
- Full blown Motorsport oil pan Killer B motorsport Oil Pickup tube
- Full blown motorsports catch can
- Custom turbo kit with a precision turbo - 6266Turbo smart BOV
- Turbo smart wastegate
- Clutch master twin disc 725 series
- Velox clutch fork
- 20 gallon fuel cell w/ two walbro 450 pumps Magna distribution block
- All fuel lines have been replaced with -6 AN Lines, and -8 AN lines
- Aeromotive fuel pressure regulator
- Radium fuel rails
- FIC 1650cc injectors
- 17+ brz intake manifold
- Hoosier radials
- M150 ECU with Motec Jumper harness
- BTI gauge pod
- Oil pressure sensor
- Coolant pressure sensor
- Exhaust pressure sensor
- 4 bar map sensor
- Flex fuel sensor
- Spal fans
- Koyo radiator
- Leg Motorsports Ducktail
- KW V3 coilovers
I do have extra parts as well that if the buyer wants them I will include with the purchase of the vehicle.
Toda oil pump gear
JDL oil cooler
Invidia exhaust
Spare block along with pistons and rods
Klutch rear wheels(to match the front)
black Plastic intake manifold
stock ECU
bryanjuz94 is offline   Reply With Quote
Old 03-12-2022, 08:21 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Sounds dangerous. Good luck with the sale though.
Old 03-17-2022, 02:53 AM   #3
alexpeter4527
Drives: Camry 2000
Where are you located?
alexpeter4527 is offline   Reply With Quote
Old 03-17-2022, 06:32 PM   #4
bryanjuz94
I am located in Stuart, FL
Old 03-19-2022, 09:22 AM   #5
bryanjuz94
Price drop
Old 03-20-2022, 12:49 AM   #6
TheGimster
Drives: 11 STI 650whp(sold); 19 WRX 402whp
Trans/synchros all stock? Also didn't see anything about the rear end - axles/diff stock?
TheGimster is offline   Reply With Quote
Old 03-20-2022, 07:14 AM   #7
bryanjuz94
Yes stock transmission, axles and diff
Old 03-20-2022, 09:52 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Open air dump pipe out the front.
So full on race car and not road legal then?
Or do you have another dump pipe that hooks back up to the exhaust on the side?
Old 03-20-2022, 10:17 AM   #9
bryanjuz94
Dump pipe out the front. I do have a invidia exhaust that will go with the car but will need a downpipe made if you want to use it. As far a road legal I have no issues here in Florida.
Old 03-27-2022, 10:47 AM   #10
bryanjuz94
Final price drop
2013 frs Turbo/built motor/flexfuel Kurd Cars for Sale/Trade 6 03-03-2021 05:29 PM
IN: 05 GTO (built motor and rearmount turbo) Subi-Subi-Ruu Cars for Sale/Trade 4 12-14-2014 08:59 PM
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
Crawford Limited Turbo BRZ - built motor Mrqb22 Forced Induction 8 11-11-2013 01:34 PM
