| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: '22 BRZ
mud guard instructions
Supposedly you get them from the dealer, but mine said they didn't exist. I put the fronts on which were pretty straightforward, and will look at the rears once I swap my summer tires on. Just curious if anyone had seen them, as I figure it'll save me a few minutes having the instructions.
Drives: '22 BRZ
Rears take more work then the fronts. Inner hole in the liner and lower rear hole need to be drilled large enough to accept the pop fasteners (at least that's what I did). Rear hole location already has a small indent from the factory. I had to swing open the caliper to get enough clearance for my drill. I was careful not to make those holes any larger then needed to be to accept the plastic fastener.
Be Kind
Drives: 2020 86
Drives: '22 BRZ
2nd gen is totally different design.
Be Kind
Drives: 2020 86
Completely my bad. I didn't even notice this was the 2nd gen section
| Here are your Rocketbunny instructions! | Maverick22 | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 04-03-2017 12:52 PM |
| BaysonR sti sideskirt instructions?! | nickmerronesucks | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-17-2014 01:04 AM |
| Modellista Antenna Instructions | Pvt AJ | DIY (Do-It-Yourself) Guides | 22 | 06-16-2014 09:06 PM |
| Instructions to install OEM mudguards? | eddieEndo | DIY (Do-It-Yourself) Guides | 7 | 02-13-2013 04:18 PM |
| Instructions for dash disassembly | whataboutbob | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 07-01-2012 07:03 PM |
