Old 02-10-2022, 09:41 AM   #1
uDasBoot
2013 Turbo FR-S Valve Spring Recall
So, I have a 2013 FR-S that I just purchased with around 80k miles. It looks like it had around 75k miles when the Valve Spring recall was issued. I don't have time nor do I really trust the dealership to do this, since they have to pull the engine and it has an aftermarket turbo kit on it. I expect to put ~1-2k more miles on it before I can replace the valve springs myself this Summer. Do I have a ticking time bomb that will blow before I can get it done this summer, or should I be fine risking it? If so, what's the worst damage that can happen to my engine if the valve-springs do fail? Since it's an H-4, the valves wouldn't drop in the cylinder, would they? As I said, I just bought this car, and I don't want it to grenade within the first few months.
uDasBoot is offline   Reply With Quote
Old 02-10-2022, 09:44 AM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Don’t get it done unless your state requires it for registration
Old 02-10-2022, 09:48 AM   #3
uDasBoot
I've heard there have been issues with it getting done improperly, is this why you're saying not to? Or is it for other reasons? I'm also wondering if I could get it done at a Subaru dealership rather than a Toyota, since they have better experience with these engines, but I'm not sure if I can get it warrantied there.
Old 02-10-2022, 10:38 AM   #4
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Subaru will not honor a Toyota Warranty. I have a 2013 FRS with the recall. It has 74k with no issues. Synthetic changes every 5k. Recently started using 5w30. I have no intention on doing it.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 02-10-2022, 11:06 AM   #5
WNDSRFR
Drives: FR-S,GTI
Just don't do it.
If the springs lasted 80K miles, then they'll probably last another 150K.
Old 02-10-2022, 12:12 PM   #6
TommyW
TommyW's Avatar
Yes. If they screw up the sealing of the timing chain cover they'll destroy the engine and there is no recourse then you have a very big bill and then need to find someone to do it and hope THEY don't screw it up. I was lucky enough to have the guru of the FA20 at my disposal for my rebuild after the dealer F'ed it up.
Old 02-13-2022, 03:24 AM   #7
humfrz
Well, like they say in the old country, if it ain't broke yet .... (something or other).
Old 02-13-2022, 04:14 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Please don't spread misinformation.
You know you were one of the outliers and were thoroughly fkd over.
But there are also a large number of people who had their engines borked and Toyota/Subaru fixed the car for free.
To OP The only reason to do the recall is if it is required by your state.
It's hit or miss if you do the recall.
However if the car is still running then why risk it.
IIRC nobody has reported a failure due to the springs on a car that did not do the recall.
Old 02-13-2022, 06:24 AM   #9
TommyW
TommyW's Avatar
misinformation? there’s a reason that people are warned to not get it done unless it’s a registration requirement. Having the motor go 6 hours from home was a fu*ing nightmare.
Old 02-13-2022, 07:02 AM   #10
x808drifter
LMGTFY
Yes it is.
But what you said was if it goes you are boned and "they'll destroy the engine and there is no recourse". (As I bolded to point you that exact comment)
Which is 100% BS as I stated.
Old 02-13-2022, 10:12 AM   #11
TommyW
TommyW's Avatar
Yes it is.
I believe it was IF THEY SCREW UP SEALING THE TIMING COVER they’ll destroy your engine. There are way too many instances of this happening to just not worry about it.
And to add insult to injury the moronic tech that did the work didn’t tighten down the clutch fork properly and while trying to nurse a car home with a knocking rod, the clutch went out in the middle of the freeway in heavy traffic. So yes some of these guys at the dealers can be pretty bad.
Old 02-13-2022, 01:44 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
2 years and 10k miles later, i'm fine.
Old 02-13-2022, 01:48 PM   #13
CedN
CedN's Avatar
Drives: 2013 GT86 fully standard
Have anyone actually had an issue with the valve springs? My car (a year before i bought it) got a new bottom end from Toyota after the recall "fix" that led to bearing issues.
2013 GT86, fully standard daily and occasional track day car
CedN is offline   Reply With Quote
Old 02-13-2022, 02:08 PM   #14
TommyW
TommyW's Avatar
The valve spring recall has got to be one of the most ridiculous recalls in history.
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 06:21 PM
2013 Scion FR-S Valve Spring Replacement Recall Aussie Northern California 29 06-22-2020 01:51 AM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 07:03 PM
*California* 2013 Valve Spring Recall Ankleguy Issues | Warranty | Recalls / TSB 14 09-30-2019 11:55 AM
Valve Spring Recall for FI (Turbo or SC) Eazy-V Issues | Warranty | Recalls / TSB 8 01-28-2019 12:56 PM
