Old 02-08-2022, 09:53 PM   #1
15WhiteFRS
Drives: 15 FRS
Tacktrix logging
Since romraider doesn't work for logging I am trying to log with the open itself. I formatted the SD card out the .txt file on it. Tried logging by pressing the defrost but it stayed yellow and I got a .out log
15WhiteFRS is offline   Reply With Quote
Old 02-08-2022, 11:02 PM   #2
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Rom Raider does work. Maybe a bent pin? Maybe something wrong with the unit? Have you tried something else, like reading the ROM with ecuflash?
Old 02-09-2022, 11:16 AM   #3
15WhiteFRS
Drives: 15 FRS
Rormrsider logger won't run on 64bit java
Old 02-09-2022, 02:24 PM   #4
15WhiteFRS
Drives: 15 FRS
https://www.dropbox.com/s/e0dzno74vh...85%29.zip?dl=0
here's the .txt file and the .out
Old 02-09-2022, 02:39 PM   #5
EAGLE5
Dismember
EAGLE5's Avatar
Originally Posted by 15WhiteFRS View Post
https://www.oracle.com/java/technolo.../#jre8-windows
That doesn't work?
Old 02-09-2022, 03:17 PM   #6
15WhiteFRS
Drives: 15 FRS
Ni even have 32 bit java installed also but romraider doesn't want to run on it and keeps choosing the 64 bit version which causes the logger to just close
Old 02-09-2022, 03:19 PM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Gotta uninstall 64 bit and 32 bit then start over with just 32 bit.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Ultramaroon (02-09-2022)
Old 02-09-2022, 03:25 PM   #8
15WhiteFRS
Drives: 15 FRS
Ughh. I need 64 bit for work.
Old 02-09-2022, 03:27 PM   #9
15WhiteFRS
Drives: 15 FRS
Know any reason why the tacktrix is not logging correctly. It seems to connect to the ecu and the defrost is triggering it but its not working correctly
Old 02-09-2022, 03:29 PM   #10
EAGLE5
Dismember
EAGLE5's Avatar
I don't know why. I haven't used logging in years, so I can't just glance and figure it out. Maybe you can set up a VM for Rom Raider? Or just use an old laptop.
Old 02-09-2022, 06:11 PM   #11
15WhiteFRS
Drives: 15 FRS
Would you happen to know if it's possible to flash an v4..03 oft tune with the same ecu calib id?
Old 02-09-2022, 06:23 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
i know at some point, the oft tunes became incompatible. i don't know which version that was, though.
Old 02-10-2022, 05:27 PM   #13
15WhiteFRS
Drives: 15 FRS
I'm just trying to find an off-the-shelf stage 1 map with launch control.
Old 02-10-2022, 10:38 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
All the OTS tunes have LC.
Ecutek logging Andreas83 Software Tuning 3 07-09-2018 11:57 PM
ECU LOGGING BRZ GT 86 FRS - what to look for the basic’s steve99 Software Tuning 59 12-15-2017 03:05 PM
10/16 Tactrix Logging Roadcone Software Tuning 4 11-01-2016 08:32 PM
OFT where do you put it when logging? TStafford Software Tuning 14 08-27-2014 09:57 AM
IAT logging, what are you guys seeing? BRZPDX Forced Induction 3 03-02-2014 02:59 PM
