| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: 2022 BRZ Limited
trailer wiring harness
Anyone tried adding a trailer wiring harness yet? I'm looking to tow a small tire trailer for HDPE's, and playing around in that back I couldn't figure out the correct way to get access to the connector for the taillights. I could pull the three accessible screws on the taillight assemblies, but I couldn't get it to come out without pulling harder than I was willing to risk without some form of instruction guidance. Didn't seem like I could access the wiring from the trunk at all either.
Drives: '22 BRZ
Curt offers a plug and play harness kit for the 2013-2020 vehicles. you need to run a power cable to the battery or find power somewhere in the rear of the vehicle. If you have an OEM amp, that is one place you could probably steal power.
2022 BRZ
Drives: 2022 BRZ Limited Sapphire Blue
I got the right taillight off last night without damage. Thinking I could identify which of the 2022 Impreza kits might work. One is the same as used on first gen BRZs and the other is different depending on sedan/hatchback. Both are 4-pin connectors. Neither works; the connector is 6 place connector with 5 pins populated. I took out the three hex/phillips screws that are visible along the top of the taillight. Not inside the car. It looks like two pieces, taillight and a small cover but they came off together. Pull straight back. There is a plastic pin towards the front that the taillight assy slides into. 10mm on the hex or be sure to use #3 phillips as they were pretty tight.
I contacted etrailer to see if they could identify the connector or a kit that might work. No plug and play kits but they have a universal that doesn't cut into any wiring. Of course it is about the most expensive kit out there.
https://www.etrailer.com/Trailer_Wir...119250KIT.html |
ProCrastinationConsultant
etrailer can sometimes be a little expensive-- they're almost the 'snap-on' of trailer equipment. so you can sometimes locate the same thing for less without the name brand stickers.
but that said, $200 for a non-destructive, fully reversible kit, that could be used on any/all other vehicles for the rest of your life, really doesn't sound like a bad deal at all.
| Curt 56212 plug and play trailer wiring, drawbar, locks | Joesurf79 | Exterior Parts (Aero, Lighting, Etc.) | 7 | 01-10-2018 11:07 PM |
| Curt vehicle to trailer wiring harness | 08stiguy | Exterior Parts (Aero, Lighting, Etc.) | 14 | 09-06-2016 08:39 PM |
| WTB wiring harness | awang0528 | Want-To-Buy Requests | 1 | 06-06-2016 02:55 AM |
| DIY Trailer Wiring | kask2_6.0 | DIY (Do-It-Yourself) Guides | 12 | 12-10-2015 03:31 PM |
| Issues with trailer wiring | qoncept | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 08-27-2013 10:42 AM |
