Old 07-15-2013, 12:21 PM   #1
qoncept
qoncept's Avatar
Issues with trailer wiring
I'm having a little bit of trouble with my trailer wiring. I realize next to no one has done it but I'm just looking for ideas. The trailer is wired using [ame=http://www.amazon.com/gp/product/B001EP0GI6/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1]this adapter[/ame].
1) A couple of times now I've started the car with the trailer lights plugged in and the ABS and traction control lights were lit.
2) Every once in a while, when the trailer lights are plugged in, the turn signal will cancel cruise control.
Neither is a huge issue but I'm concerned about what the cause might be. I'm guessing the cause of #1 is that the lights are drawing too much current, but I'm not positive. The brake lights are LEDs of course, though, and the lights on the trailer are incandescent (plus the adapter is probably using a bit). I'll probably buy some LED lights for the trailer but I'd like a sanity check first.
#2 I don't have a clue about, unless there's a ground loop fault or something in the adapter, which could explain #1, too. Any other ideas?
qoncept is offline   Reply With Quote
Old 07-16-2013, 11:17 PM   #2
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
You need something like this: https://www.etrailer.com/Wiring/Curt/56146.html
Uses the signal from the tail lights but draws power from whatever you wire it to.
Also, it doesn't look like the one you have has power for running lights?
kask2_6.0 is offline   Reply With Quote
Old 07-17-2013, 10:18 AM   #3
qoncept
qoncept's Avatar
Mine isn't providing any extra power, just combining the 3 wires for brake, turn signal and running lights in to the 2 wires the trailer lights use. I'll have to pick one of those up. Thanks!
Old 07-17-2013, 10:30 AM   #4
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
From my understanding the turn signals are controlled by the ecu and not an external unit. So it will do some weird things if the flashers are drawing too much or are feeding back power somehow.
@ScoobySouth may have some input as well.
Old 07-17-2013, 10:39 AM   #5
qoncept
qoncept's Avatar
I expected their might be some issue. The brake lights are LED and the gauge of the tail light wires is very small. It's intermittent and happened both times in the morning, not on the way home in the afternoon.
That adapter you suggested is cheaper and more "right" than putting LEDs on the trailer so I'll go ahead and try it. I'm pretty sure that will fix it.
Old 07-17-2013, 01:34 PM   #6
voyager2285
voyager2285's Avatar
Drives: WRB BRZ
Sorry for being a bit off topics, but I'd be interested in how you got your trailer hooked in the first place!
voyager2285 is offline   Reply With Quote
Old 07-17-2013, 01:47 PM   #7
jonzhuxD
Drives: Ultramarine FR-S
kask2_6.0 has a hitch receiver for sale!
http://www.ft86club.com/forums/showthread.php?t=40098
jonzhuxD is offline   Reply With Quote
Old 08-21-2013, 09:14 AM   #8
swift996
swift996's Avatar
I went ahead and ordered one of these:
http://www.jegs.com/i/Curt+Hitches/2...FaaDQgodA0sAjg
Should be here on Friday and leave for the track on Saturday. Any tips or pointers?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 08-21-2013, 11:41 AM   #9
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
^^ would also like to know how this works out
Ryaquinn is offline   Reply With Quote
Old 08-27-2013, 04:32 AM   #10
riyal
Drives: 2013 Toyota 86 High MT
Originally Posted by qoncept View Post
I'm having a little bit of trouble with my trailer wiring. I realize next to no one has done it but I'm just looking for ideas. The trailer is wired using this adapter.
hey bro,
not completely off topic but i know here (south africa), the manual explicitly states no towing with this vehicle. and that tow hitches void warranty, not sure tho on bike racks etc. perhaps its just for our market, just thought i should share (if you already didnt know)
why not run power from the battery (with a fuse) and use some relays (tap into the tail lights for signal/switching) to isolate the trailer circuit from the car. that should keep strain on the cars electrics but could be a bit of a mission to run the power cable.
anywho either way hope you sort a solution out. cheers
riyal is offline   Reply With Quote
Old 08-27-2013, 10:42 AM   #11
qoncept
qoncept's Avatar
I'm not really concerned about warranty. I did buy a different adapter that is externally powered but I've been too lazy to install it yet.
Trailer Hitch Jack Black Tracking / Autocross / HPDE / Drifting 31 12-22-2015 08:26 PM
Need Low Profile Trailer..Someone Help whitefrs Tracking / Autocross / HPDE / Drifting 0 06-02-2013 05:59 PM
Uhaul Trailer whitefrs Other Vehicles & General Automotive Discussions 9 06-02-2013 04:32 PM
Iron Man 3 Trailer kanundrum Off-Topic Lounge [WARNING: NO POLITICS] 6 03-15-2013 10:17 AM
Scion tv trailer warplane95 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 05-19-2012 06:44 PM
